my truck's dead and sitting at the gas station
help guys, I got off the highway and stopped at the gas station to get a Pepsi, I walk back out to the truck and try to start it, it turns over but won't start, I didn't notice anything before I shut it off, any ideas?
the truck is an '88 GMC fullsize longbed, 305 with 109,000 miles |
See if it's getting gas at the carb and if it is try seeing if it has spark at the plugs.
Did you try sarting the truck after the engine had ample time to cool??
1) its got EFI
2) I let it sit and tried to start it 5 different times |
as nasty as the stuff is, spray some starting fluid into the throttle body and try starting it, if it kicks like it wants to start then it's fuel related (pump, filter, no gas) if it does nothing but turn over then it's ignition (no spark) or mechanical (timing chain)
Like the others have said, you’re not getting a spark, gas, and air. It is one of those three.
Pull the air filter completely out. If the filter is clogged it will choke a warm car. Check for spark at a plug. Ether you have it or you don't. Shoot some starting fluid where the air intake is. If it starts, you know the issue is fuel. Once you know which of the three it is, let us know and we can trap the issue. |
If you have spark Have someone crank it and hit the bottom center of the gas tank with a hammer , may get the fuel pump running long enough to get it home , if it is the pump, we do this all the time to move vehicle's in to the shop and this is the first thing we check on a no start like this, sounds funky but it works most of the time if its the pump. If no spark check the coil we change a lot of coils on the GMs .
Try changing the module in the HEI distributor,I had just the same problem and doing that worked.
one of three things most likely. fuel pump, coil, or module in the distributor. One of these three things should work
we towed it home, and it started right up :eek: so we're befuddled!
I was thinking module as well;)
Since it started after you got it home, I would suspect the fuel pump relay. Had an Oldsmobile that had the same problem then mysteriously started the next day. Happened a few more times before I discovered the bad relay.
we're just gonna replace the whole pump and call it good, thanks for all the help guys
| All times are GMT -6. The time now is 01:03 AM. |
