my truck's dead at dead and sitting at the gas station - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-05-2003, 01:08 PM
I fight what you f33r!
Thumbs down my truck's dead and sitting at the gas station
help guys, I got off the highway and stopped at the gas station to get a Pepsi, I walk back out to the truck and try to start it, it turns over but won't start, I didn't notice anything before I shut it off, any ideas?
the truck is an '88 GMC fullsize longbed, 305 with 109,000 miles
Old 09-05-2003, 02:14 PM
johnsongrass1's Avatar
Race it, Don't rice it!
See if it's getting gas at the carb and if it is try seeing if it has spark at the plugs.
Old 09-05-2003, 02:15 PM
Did you try sarting the truck after the engine had ample time to cool??
Old 09-05-2003, 02:21 PM
1) its got EFI
2) I let it sit and tried to start it 5 different times
Old 09-05-2003, 02:58 PM
engineczar's Avatar
as nasty as the stuff is, spray some starting fluid into the throttle body and try starting it, if it kicks like it wants to start then it's fuel related (pump, filter, no gas) if it does nothing but turn over then it's ignition (no spark) or mechanical (timing chain)
BSE Racing Engines
Old 09-05-2003, 03:06 PM
DragTour69XL's Avatar
Galaxie Man
Like the others have said, you’re not getting a spark, gas, and air. It is one of those three.
Pull the air filter completely out. If the filter is clogged it will choke a warm car.
Check for spark at a plug. Ether you have it or you don't.
Shoot some starting fluid where the air intake is. If it starts, you know the issue is fuel.
Once you know which of the three it is, let us know and we can trap the issue.
Old 09-05-2003, 03:31 PM
roys63's Avatar
If you have spark Have someone crank it and hit the bottom center of the gas tank with a hammer , may get the fuel pump running long enough to get it home , if it is the pump, we do this all the time to move vehicle's in to the shop and this is the first thing we check on a no start like this, sounds funky but it works most of the time if its the pump. If no spark check the coil we change a lot of coils on the GMs .
Old 09-05-2003, 04:07 PM
malc's Avatar
Living At The Speed Of Life
Try changing the module in the HEI distributor,I had just the same problem and doing that worked.
Old 09-05-2003, 04:44 PM
one of three things most likely. fuel pump, coil, or module in the distributor. One of these three things should work
Old 09-05-2003, 05:29 PM
we towed it home, and it started right up so we're befuddled!
Old 09-05-2003, 06:26 PM
I was thinking module as well
Old 09-05-2003, 09:39 PM
drlindz's Avatar
Since it started after you got it home, I would suspect the fuel pump relay. Had an Oldsmobile that had the same problem then mysteriously started the next day. Happened a few more times before I discovered the bad relay.
Old 09-05-2003, 09:43 PM
we're just gonna replace the whole pump and call it good, thanks for all the help guys
