Is my Valve Guide cutter broke? - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-10-2012, 12:18 PM
zildjian4life218's Avatar
Listen and Learn
Last wiki edit: DIY junkyard electrical fan controller
Last journal entry: SBC 305 Twin Turbo
Wiki Edits: 7
I was cutting down the valve guides on a set of vortec heads today and I noticed it seemed like I couldn't keep the cutter seated. Its a Comp-4726 cutter.... any ideas what could be happening? I have always set the drill to a slow speed and used lots of cutting oil when I used this.
Thanks everyone!
ID:	65324   Click image for larger version
ID:	65326   Click image for larger version
ID:	65327   Click image for larger version
ID:	65328   Click image for larger version
Old 05-10-2012, 03:10 PM
No offense, but did you have the correct pilot installed? That's the only thing I can think of that would keep it from being square since the carbides look good. Comp shows an 11/32 and 3/8 I think.
Old 05-10-2012, 05:25 PM
Listen and Learn
Wiki Edits: 7
I have the 11/32 one. Fits good.
Old 05-11-2012, 08:52 AM
Listen and Learn
Wiki Edits: 7
I did go out today and noticed that the cutter and pilot can rock slightly back and forth just like checking a valve guide.
Old 06-07-2012, 12:53 PM
Listen and Learn
Wiki Edits: 7
I was watching some youtube videos on cylinder head machining and noticed a lot of guys use a bounce spring under neath their cutters. Could this have something to do with it?
Valve guide clearance Chevyjeepster Engine 7 11-18-2011 06:58 PM
valve guide cutting, dual valve springs ekacpuc Engine 3 08-12-2011 07:39 AM
Valve Guide Fixable? johnsongrass1 Engine 8 01-05-2011 09:41 PM
Valve Guide Changes... hallamwillis Engine 3 04-17-2007 06:59 PM
Can the dual coil valve springs on a BB destroy Valve guide seals Auto-Part Engine 4 11-25-2003 06:23 PM
