Are my valves adjusted to tight? - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-06-2008, 09:04 PM
I started my truck up today and held a dollar bill up to the tail pipe it kind of sucked it in and blew it out is this bad valve lash?
Old 12-07-2008, 12:27 AM
DoubleVision's Avatar
Exhaust systems have positive and negative pulses. The positive is out, the negative is in. In most cases you don`t need to use a dollar bill, your hand works just as well, the pulses from the exhaust system cause it to suck in just as well as pushed out. I can`t say I ever heard of checking valve train lash by exhaust pulses before.
Adjusting valves on SBC after cam install tnman Engine 15 11-16-2010 01:13 AM
How do I adjust my Valves ? Low compression Tony Chavez Engine 2 11-28-2006 12:19 PM
Adjusting Valves and Fuel Pump Install demitristewart Engine 5 08-09-2006 11:10 AM
Question on Aftermarket valves & machining heads unstable Engine 9 05-26-2004 09:50 AM
2.02 valves camino_man Engine 5 01-19-2004 09:19 AM
