My valves are too loud!! - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 05-23-2012, 06:05 PM
thanks for the advise, I'll inspect the faulty lifters first, I was thinking I might replace cam and lifters anyway. I have long slot rockers and no coil bind.
  #17 (permalink)
Old 05-23-2012, 06:07 PM
Thanks Jim, comp and leak test are next on my list, hopeful Saturday I can squeeze them in.
  #18 (permalink)
cobalt327's Avatar
WFO
Wiki Edits: 1616
Here are some things to check while you're looking.
  #19 (permalink)
Old 05-24-2012, 01:41 PM
seven1nova's Avatar
Ok you got oil up top.
The right rockers long slots.
No coil bind.
All rockers moving the same amount.
If this is a new motor, or a new cam, maybe you got junk in the lifters, Assembly lube, or dirt, what ever. Here is what I would try first before tearing it apart. Whatever lifter is ticking run it down, bottom it out (with the car off of course) squeeze everything out of the lifter then reset your lash. It would be better to put the particular lifter on its base lobe of the cam. Fire it up and let the lifter re-fill and see if that helps..
  #20 (permalink)
Old 05-25-2012, 07:48 AM
boatbob2
valve noise.
Hi,after checking out everything that has been said in prior postings,with no results,,drain your oil,add 2 qts of trans fluid (ATF) to the replacement oil,this is SUPER HI-DETERGENT oil,start the engine,(keeping an eye on the temp guage),it will clean up all the dirt,(maybe the dirt is what causing the noise.) i usually do this about once a year.
not loud DARK SIDE Engine 15 07-10-2010 10:04 PM
as loud as possible princess Hotrodders' Lounge 42 01-20-2007 10:30 PM
How Loud??? nova_man72 Engine 7 12-15-2003 10:58 AM
How loud? Forsaken502 Engine 10 09-07-2003 12:44 AM
It's too loud! jpd37 Engine 8 04-25-2003 11:53 AM
