My valves are too loud!! - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-24-2012, 07:52 PM
Hello anyone, I have a 496 big block everything new. I hear what I assume is valves clacking over my mufflers. It's annoying, cannot adjust it out, it's not exhaust leaks or valve covers. It idles rough enough to shake the whole truck. I can feel knocking on the rocker studs, I checked rocker clearance and no contact. I'm out of ideas. Iron block, aluminum heads cam 567 lift 246 duration, 1:7 roller rockers. Any ideas will be very helpfull, thanks.
Old 04-24-2012, 08:07 PM
Hard to tell from the info. Hyd roller, they're going to be loud. Got one in my deuce, it's loud. Set the valves hot. I run 15w40 in mine to help quiet it down. Puta screwdriver on the valve cover while it's running to verify it's coming from the valve cover. If not, chase it down.
Old 04-25-2012, 05:38 AM
BOBCRMAN@aol.com's Avatar
Check for correct pushrod length. BBC's usually need custom pushrods with non-stock builds. Or you have pistons contacting the heads, another common problem. Especially with some Edelbrock heads.
Old 04-25-2012, 10:02 AM
Banned
How's the oil pressure?
Old 04-25-2012, 11:34 AM
Hydraulic or solid lifters?
Flat tappet or roller?
Rocker body hitting stud?
Cam degreed in and specs verified at assembly?
Piston to valve clearance?
Old 04-25-2012, 11:36 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Rocker hitting the v-cover? Exhaust leak?
Old 05-21-2012, 07:24 PM
Valves are to loud
First of all, thanks for your replies. No exhaust leaks, oil press good rockers are clear of studs and valve covers. Lifters are hyd. Flat. Don't know about cam degree or piston clearance, this is the first engine I DIDN'T build, trying to save time, now I'm spending way more time on this than if I'd done it my self....Lesson learned. I'm starting to think the cam is the wrong size. In it now is an Elgin 576 lift, 246 duration. What should be in a 496 for mostly street use?valve noise has gone down a little after changing guide plates but still shakes so bad it feels like the doors are going to fall off.
Old 05-22-2012, 01:41 AM
blwn31's Avatar
If you are truly concerned,and believe there is a problem, take the motor back to the builder. He should stand behind his work, if there is a problem.
Keith
Old 05-22-2012, 05:11 AM
engineczar's Avatar
What size studs? Possibly 7/16 rockers with 3/8 studs? Probably not the case but you never know.
BSE Racing Engines
Old 05-22-2012, 02:37 PM
seven1nova's Avatar
Are you getting oil up top to the rockers?
Old 05-22-2012, 06:45 PM
yes, plenty of oil. I noticed some of the lifters were spongy after shutting it off, I'm going to change them and see if that helps, thanks.
Old 05-22-2012, 06:50 PM
The builder is in Ca and I'm in Tx, all he says is adjust the valves which I've done repeatedly, he is no help. The rockers and studs are both 7/16.
Old 05-22-2012, 07:28 PM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
I've got a BB in my T, with valve cover extenders to raise the cover for rocker clearance. With heavy PRW roller rockers that came with it, they hit the valve cover lift extension on the top side, some have been ground down, but a couple still hit when it warms up.
Semper Fi
Old 05-22-2012, 09:33 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Not a good idea, changing just the lifters on a FT cam that's been run in w/a different set of lifters. More here.
Old 05-23-2012, 06:02 PM
Agreed with F-Bird. What type of rocker? Stock? Lots of cam for stockers.
Also, running "rough" is not necessarily related to the clatter. Generally, a "tight" valve will cause a "miss", and a "loose" one will clatter. Do a compression test and/or a leakage test. Make sure of the conditions inside.
Jim
not loud DARK SIDE Engine 15 07-10-2010 10:04 PM
as loud as possible princess Hotrodders' Lounge 42 01-20-2007 10:30 PM
How Loud??? nova_man72 Engine 7 12-15-2003 10:58 AM
How loud? Forsaken502 Engine 10 09-07-2003 12:44 AM
It's too loud! jpd37 Engine 8 04-25-2003 11:53 AM
