my wifes 2000 tahoe - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-22-2006, 07:16 PM
my wifes 2000 tahoe
hope im asking this in the right area. my wife has a 2000 tahoe when she starts it first thing in the morning it starts great. after she shuts it off dont start real good. starts real at real low rpm have to give it gas to keep it running. and have to crank it real long i put some injector cleaner in it. the car only has 40,000 miles on it just made last payment so time to start messing up right.lol. does any one have any advice for me? thank you for any help.
Old 02-22-2006, 07:41 PM
66GMC's Avatar
Get in, sit down, hang on
Last journal entry: Cab Removal
Have you had this thing checked for codes?
Any lights on the dash? Any of them flashing when you first turn the key to "run"?
Black smoke?
Can you hear the electric fuel pump running?
Old 02-22-2006, 07:45 PM
302 Z28's Avatar
You should have some problem codes set in the VCM. Do you know how to retrieve them?
Vince
Old 02-22-2006, 08:02 PM
no check engine lite on . no black smoke runs fine after it starts dont have a clue how to get the codes. do i have to take it in and put on computer?
Old 02-23-2006, 09:33 AM
Demondrive's Avatar
scanner
most of the time shops will check and clear codes for you fairly cheap, mine does it for free, but we only work on mercedes =) but i also know you can buy a scanner, im not sure how great it is or how versatile it is btween car types and code explenation....they have them at harbor Freight and im sure many other places, but even if the light isnt on, there will most likely still be a code stored in the ecm, also if its a good scanner you can moniter the data stream of the engine and that might help as well, mass airflow meters tend to do that sometimes, but get the codes checked first.
Old 02-23-2006, 10:48 AM
1931 steve's Avatar
Last wiki edit: How to rebuild an engine Last photo:
Wiki Edits: 4
Sounds like it could be a bad sticky fuel injector. Does it run rough during the hard start/low idle? These trucks had a lot of problems with plugged injectors and most of the time I have found a bad injector, that cylinder # will soon show a bad cylinder head. Hope this is not the case for you. Have you been using any coolant lately?
Steve
Old 02-23-2006, 01:34 PM
Check for codes,the Autozones around here will do it for free!!!!!
Check Fuel Pressure, i would have to look it up for sure but i think it should be between 52-60 psi.
Do a leak down test on the fuel system, these trucks are known for sticky injectors and will leak fuel into the cylinders, making for a overly rich condition until the extra fuel is burned off.
Old 02-23-2006, 08:45 PM
Might also check to see if the throttle blades are getting dirty. There's a spray cleaner for them if you need it. If there's an idle air bypass, it might need a shot, too.
Pro Topline Heads surfinca Engine 33 12-28-2008 11:37 AM
2000 chevy tracker speedometer out mychevystang Electrical 3 06-08-2005 09:38 AM
98 Tahoe to 68 Truck Earl E. Model Suspension - Brakes - Steering 5 02-06-2005 10:00 AM
Dome light ? in 2000 Chevy Venture. bowtieorbust Electrical 5 06-27-2004 12:24 AM
68 Camaro 10 bolt & 2000 truck limited slip 68CaliCamaro Transmission - Rearend 6 12-22-2003 04:57 PM
