Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Mysterious A/C problem on 98 Cavalier 2.2L.
Old 07-29-2012, 01:45 PM
LATECH's Avatar
LATECH LATECH is offline
If you hooked a can on with a gauge for the low side only, then you cant tell much. The compressor may not be pumping well, which would make the low side read high, and not take freon.Your just going to have to hook on a gauge set to figure it out.
Fact is stranger than Fiction
