re: Mysterious fuel pressure problem
The gas was siphoning out of the tank. Fuel can run right through a mechanical pump, gravity was just draining your fuel into the bucket. (Yes, at a surprisingly high pressure.)
Uhmmm
This is the first time I have experienced that! I have worked on my Camaro several times and didn't have that problem. Thank you for the information. I wasn't aware it could still flow like that through the pump!
You sure that you dont have an electric fuel pump that you dont know about?. I cant see syphoning having that much pressure, and when you lift the hose above the fuel level, it would stop......Your tank must be building up some pressure.
Ontario Rodders |
The pressure really depends on the difference in height between surface of the fuel in the tank and the end of the hose. Yes, if you raise to hose above the level of the tank the flow should stop. If it doesn't, you have something else going on.
The tank vent system could also be plugged and creating pressure in the tank, the only place to release it would be through the fuel line...or the cap when you open it. If you take the cap off and the fuel stops, that's probably the problem, otherwise I wonder about an in tank fuel pump as well. It shouldn't be operating with the ignition off though, unless the relay was bypassed at some time. That would probably run the battery down when it set though.
It`s a vent issue. Check the vapour line going to the carbon canister, if it`s plugged off or stopped up pressure build up occurs. Next time when you have to remove the fuel hose take the gas cap off first. I had this same problem with my cutlass, it would build pressure all the way up to 14 -15 psi and it was blowing the rubber tip off the needles in the carb.
Ok...
I haven't tried to remove the cap yet. I was thinking that with the line above the engine it shouldn't be pulling fuel through. Now that you mentioned it, I think I seen that someone removed the carbon canister when I was working on it. Uhmmm, I better check the to see if the vent lines are plugged off. This carb was only 6 months old and it started flooding the engine. I replaced all the gaskets and installed new needles and seats! Maybe the pressure problem is related to the carb problem!
About 3 1/2 ft of elevation makes 1 pound of pressure. |
Hey, a person can blow about 3 psi. Have you ever blown on a small hose full of water? Sure, me too. 1 or 2 psi will shoot a 5/16 stream a looooong way.. So just a little fall makes it look like a lot of pressure to the eye. |
| Small Block Chevy Oil Pressure | knizet | Engine | 25 | 03-21-2008 04:21 PM |
| Crankcase pressure effect on oil pressure? | cboy | Engine | 8 | 06-12-2005 08:04 AM |
| 4L80E diesel computer | 5foot2 | Transmission - Rearend | 2 | 04-09-2005 12:48 PM |
| Oil pressure loss SB Chevy | Finmike | Engine | 30 | 06-12-2004 10:27 AM |
| Fuel Pressure Variance | slomotion | Engine | 2 | 04-02-2002 01:25 PM |
