Mysterious Oil Leak - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-01-2004, 11:21 AM
DoubleVision's Avatar
Mysterious Oil Leak
Dealing with a oil leak on my SBC, I`ve been finding oil all over the passengers side fender well, but it`s all to the back, the drivers side shows little. The bolt is in the fuel pump hole, so I know it`s not coming from there, this problem didn`t start until I changed valve cover gaskets, but it`s not coming from there either, most of the front of the engine has oil on it, there`s even oil dripping off the lower radiator hose, there`s also oil on the bottom of the alternator. before when the balancer seal went out there was oil straight out from the belts on the fender wells, it would even do it at idle, this time it only does it while driving.
Upon closer inspection, there is oil over the top of the china wall where the intake seal is, I used permatex here instead of the end seals, so I didn`t think this would leak and it hasn`t before and I don`t see why it would start now, but there was some oil on the intake and some on the water neck, there`s oil on the back of the water pump and all over the timing chain cover, is it possible the intake seal on the china wall is bad and it`s just leaking when the cars moving since the engines at RPM? since there`s no oil leaks while at idle this is all I can come up with, but I`ve never seen oil go up before in any leak like it has this time, any help here is appreciated.
Old 09-01-2004, 11:49 AM
aka Duke of URL
Question
How is the PCV System setup?
Old 09-01-2004, 01:46 PM
Disregard. I went on ahead and snatched the balancer and decided I`d look at the seal, the seal is completely shot, I took it out, and even with the seal saver on the balancer, the seal will slide on with no effort at all and fits real sloppy. I`m thinking when I changed balancers a few times due to keyway problems it ruined the seal, but the car was run hot about 2 weeks ago and it showed up around that time also and right afterwards was when I changed valve cover gaskets, maybe the heat made the spring on the seal loose it`s tension. Now on to problem number 2. I`m reinstalling the A/C in my car, I`m running a single water pump pulley, so I went to install a double groove off a 305, now the pulley`s don`t line up, so I dug out a crank pulley that also came off a 305, I compared the 305 and 350 crank pulley`s, the pulley`s are the same diameter, but the 350 pulley is taller, so if I installed the 305`s crank pulley it would put them even more out of alignment, so I`m kinda stumped, I`ve delt with pulley`s on small blocks for years and never ran into this problem. as far as I recall the A/C belt goes over the water pump as well as under the power steering pump, so it`s got me confused. But If I`m wrong here somebody let me know. thanks.
Old 09-01-2004, 03:15 PM
Ghetto Jet's Avatar
current hot rod: CTS-V
Last journal entry: Lets Get Started With the Improvements
D.V. the belt for my A/C runs around the power steering pulley, crank pulley, and water pump pulley. Thats an 85 Caprice 305.
Old 09-01-2004, 03:30 PM
MI2600's Avatar
Member# 3287
DV,
I didn't think there was a difference between the 305 and 350 pulleys.
How far are they off?
One belt should run water pump, PS, crank.
The other belt should run water pump, PS, AC.
The alternator runs crank, water pump.
Can you shim?
