Mystery posi carrier? - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-07-2005, 03:54 PM
Hey guys and girls
Ive got a posi carrier that i cant seem to identify.was hoping someone would know what it was.
-uses 12 bolts to attach ring gear
-uses c-clips to attach axles
-was removed from a gm 10 bolt rear differential
-is pysically larger than a 8.5" carrier
-ring gear is pysically larger than a 8.5"
-the casting numbers are 17-2 R 3
-uses 28 spline axles
-and its a posi eaton syle carrier
Name:	new stuff 017.jpg
nother pic
Name:	new stuff 018.jpg
Old 02-07-2005, 03:55 PM
Last one
Name:	new stuff 019.jpg
Old 02-07-2005, 04:10 PM
skeeveman's Avatar
I am the Antirice
I searched ebay, and found this carrier and thought it looked pretty similar.
Old 02-08-2005, 11:46 AM
Yip thats the one talk about an odd ball carrier must be one hell of a tough unit because its noticably larger than the stock 10 bolt carrier and uses a larger ring gear and bearings yet sit in a 10 bolt rear end
Old 02-09-2005, 11:19 AM
I think you have gotten yourself a type"O" 12 bolt. they were used in oldsmobiles in the early seventies
Old 02-09-2005, 11:32 AM
never hear of a type o 12 bolt?Do you have a link to some info on it?
Old 02-10-2005, 04:11 PM
abstruse dutch uncle
You might try oldsmobility.com
Not much mention of it, but it's out there.
