The one time I had a rotating assembly out of balance it vibrated all the time. I would look at a rear transmission bearing being bad. I have seen drive shafts loose in the rear bearing cause a coming and going vibration. What I have done but can be dangerous is jack the car up and run it in gear with stands under it. You can lay beside NOT UNDER the car and sometimes see what is shaking.
The "come and go" with speed and load changes indicate a drivetrain issue more likely that the engine...
454me suggests a rear transmission bearing, and that could be. I would also take a look at u-joints -- has anything changed in the driveshaft geometry? Sometimes a change in the angle of the drveshaft between the trans and the axle can cause a problem. |
Possible that you have wrong flexplate on there?
How about a motor mount? With all that new power maybe its flexing enough to cause driveshaft angle to be excessive? http://www.sallee-chevrolet.com/frame.html http://www.sallee-chevrolet.com/Pric...646-0.886.html FLEXPLATES 00471597 BBC and SBC - A/T Mark IV 396/427 and some small-block Chevrolets, internal balance. Large Converter Patern Only. Heavy duty 14001992 BBC A/T Mark IV 454 external balance 14096987 BBC M/T Mark V 168 tooth 03993827 BBC M/T Mark IV std. weight external balance 03963537 BBC M/T Mark IV light external balance DAMPERS 03879623 BBC 8” 427 internally balanced 10216339 BBC 8” 454 externally balanced 10051171 BBC 8” 454 external Fluidamper |
I had developed a vibration with my car at 3500 rpm , below it was gone above it had a humming noise with it. Turned out I lost a drive shaft weight. A big one at that 10 oz out of balance. Something you may want to check out.
Joe |
Thanks for the replys guys. I am starting to suspect the tranny. I'm sure I have the right flexplate. It's a Hughes pt #HP3994. BBC 454, 168 tooth, Ext. Balanced, Mark IV. I took it for a 30 minute test drive today. I found that it doesn't vibrate at al through first and second gear at any RPM. It seems to vibrate the most at 2800 RPM in third gear. I would take it to 4000 RPM in second gear and hold it there and listen...No Vibration, so I would then shift into third and instantly hear the vibration again.
Come to think of it I really beat the hell out of it before I took the old 454 out. It's possible I messed something up then. I'm thinking of buying a hughes turbo 400 unless anyone has something bad to say about them. 454me - Thanks for the info about the rotating assembly. To pmeisle: Driveshaft geometry has not changed. I spent some time obtaining 2 1/2 degrees negative pinion angle with the opposing and equal 2 1/2 degrees at the tranny yoke. The drive shaft has always had four small weights, two on each end. They are all still there. Last edited by Dano1972; 06-19-2005 at 11:40 PM. |
Only in third, probably a transmission bearing going bad. Happened to me once coming home from a road trip, vibrated a little in third and during 3-4 shifts, eventually burned up. Only good thing was that it only had 13,000 miles, I worked in transmission product group at the time, and the chief engineer had Ford put in a new one for me.
| Cant post | NovaSS350 | Hotrodders Site Suggestions and Help | 6 | 03-12-2005 04:24 PM |
| Open Loop troubles (long post) Revisited | tnoftsger | Engine | 22 | 03-08-2005 04:58 AM |
| Engine Vibration | sfeddie | Introduce Yourself | 5 | 12-07-2004 09:52 PM |
| Post counts | xtreme off-road | Hotrodders' Lounge | 23 | 03-18-2003 12:18 AM |
