Nailhead T-400 tranny with manuel valve body swap to back to auto - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-28-2011, 10:44 PM
Petematthews's Avatar
Im going to swap this nailhead th400 back to a full automatic but im not sure what i have to do. Anyone have details? Step by step Pictures ?
Old 08-28-2011, 10:51 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Forward shift pattern or reverse shift pattern?
If it is a forward shift pattern the mods for full manual shifts are different from brand to brand of manual valve body.
Need more information
Old 08-28-2011, 11:24 PM
how to
How would i go about finding that out? The tranny was in a speed boat.
Old 08-29-2011, 06:17 AM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
You need an experienced transmission person to look at this unit. I would venture a guess that the shift pattern is 'forward pattern" ; P R N 3 2 1 ..
If the trans was used in a boat, often all the parts used for "park" is removed since they are not needed in a boat.
Often the trans internal linkage is also blocked so first gear is not used.
Old 08-30-2011, 12:43 PM
i'd rather do it my self
I see, I'm looking to learn by trial and error, I'm not going to learn anything by taking it to someone unless they show me what i need to be looking for.
Old 08-30-2011, 07:19 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
An experienced person will know what to look for as the modifications. Sometimes reverse gear is also deleted.
Boat people say reverse gear in some setups can cause the prop retaining nut to back off and an expensive prop drops to the bottom of the lake. I would think there is a way to prevent that.. but I am not a boat person.
good luck. post more questions if you have them. Plenty of folks here to help
Old 08-30-2011, 11:06 PM
Trans
Sounds like I may have picked up a parts tranny, but I'm still going to tear into it and see if I can figure out what I've got. If I can swap it back that would be ideal but I have another one so I can use it for parts if all else fails
Old 08-31-2011, 10:38 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
pull the pan and have a look see. Post a few photos if you can. Maybe all the parts are there
Old 10-19-2011, 04:38 PM
I was able to get my Super Turbine code BL trans out of a 64 buick electra 225 nailhead partially taken apart today. It has a new disconnected solenoid, the fluid is RED and i don't smell anything burnt as of yet. It has a heel print in the pan with one dimple and the torque converter has the center spot welds which according to some people online is a switch pitch converter. I plan to use this trans for parts if i can as i have the manual valve body 400 out of a boat i will get into next. The red 400 is the one out of a boat. I will possibly be looking for a rebuild kit or at the very least a set of gaskets.
ID:	59041   Click image for larger version
ID:	59042   Click image for larger version
ID:	59043   Click image for larger version
Old 10-20-2011, 10:12 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Switch pitch t-400 trans is easy to tell from regular t-400 by the stator tube design at the input shaft. Splines on stator tube are more narrow and there is a smooth section with hole in it for oil to flow. I have photos of this which would make the ID for you easy. Cant find the foto this evening, must be on the other computer.
Old 10-21-2011, 01:30 AM
SSedan64's Avatar
Most of the Pans have 3-dimples & the Heel print. The Heel print's where the filter Pickup sets.
Those Filters are pricey. http://www.transmissionpartsusa.com/...-000046919.htm
Alot of SP Info here >> http://www.442.com/oldsfaq/oftsp.htm
Old 11-12-2011, 01:13 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
here is a photo of the switch pitch stator tube of the t-400 trans. This will be sticking out the front of the pump.
Notice narrow splines and long smooth section with an oil hole in it.
Tranny swap-auto-4spd mk8-78tabubba Transmission - Rearend 2 11-28-2004 11:30 AM
Manuel Valve Body danarmstrong Transmission - Rearend 2 11-07-2004 08:19 AM
auto - std tranny swap montea Transmission - Rearend 4 01-22-2004 12:28 AM
4 spd/ auto tranny swap 73monte Transmission - Rearend 2 11-29-2003 07:08 AM
400 auto tranny in a 72 GMC sprint. gearheadgirl Transmission - Rearend 1 02-18-2003 11:17 AM
