Name this chevy speedo cable part - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-30-2012, 12:52 AM
Can anyone tell me what this device is and why it is inbetween the speedometer cable and the housing of the sm-465 4 spd manual transmission on my truck? The cable will screw directly to the transmission so this must have some purpose. It also says "made in usa" on it so it might be illegal...
It is made by by stewart warner. I've run the truck without it today and I can tell the speedometer is off some without it.
Old 08-30-2012, 02:06 AM
Wiki Edits: 85
Ratio change box.
Reduction box.
The ratio is stamped on the box.
Old 08-30-2012, 04:06 AM
SSedan64's Avatar
X2^^, or Ratio Adapters. Used with Large Tires or gear changes etc...
Speedometer Gear, Speedometer Gears, Ford, GM, Dodge 700R4 ratio adapter
Old 08-30-2012, 09:56 AM
speedo cable part
There are 4 screws holding this thing together. I assume it's just some gears inside. Can it be taken apart, cleaned and relubed without messing it up somehow?
Old 08-30-2012, 10:43 AM
ogre's Avatar
the 'Duracell Project'
nice site ssedan64
thanks for posting it
Old 08-30-2012, 07:01 PM
user151's Avatar
Not meaning to be rude, but if you didn't know what it was, I'd say you can't.
Anyway, why would you want to?
Old 08-31-2012, 08:43 AM
RWENUTS's Avatar
You can take them apart. Just go slow so both gears stay on one side. Some of those allow you to change the gears inside for different ratios. Some don't.
And not to be rude but you'd definetly want to take it apart to see what makes it tick. You'll never understand how it works if you don't take it apart. JMHO
Old 08-31-2012, 10:43 AM
Wiki Edits: 85
All that is inside is two or three gears. As long as you don't lose the gears or get them mixed up, you should have no problem exploring the insides.
Speedo cable itsandre Transmission - Rearend 1 06-13-2011 10:44 PM
Speedo cable blues Vela Transmission - Rearend 12 08-31-2010 10:12 PM
speedo cable problems? 77formulabandit Transmission - Rearend 1 09-02-2008 07:02 PM
Which speedo cable for a 350 chevy/autometer gauges? RodFather Transmission - Rearend 3 09-20-2006 12:33 AM
How can i extend the speedo cable. 7t2HQ Interior 6 11-19-2004 05:11 PM
