name that head... - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-08-2013, 07:21 PM
name that head...
have a 66-67ish 283 with powerpak heads casting 38845_0. all the info i can find is for 3884520 - mine literally has a space (no 2). Date is K286 which should be Nov 28 1966 - that matches a 3884520 (except mine has no 2 )
Question 1: is a missing # normal?
Question 2: the plugs that came off it are tapered peanuts. but i got the car on trade and have found some "interesting" mechanic work (like torque converter bolts that fall out - 2 of them). so i'm not sure what was in it should be in it. everything i'm reading says the 13/16 flat gasket plugs. I do have an HEI so i believe gap is 40-45.
any help much appreciated.
Old 04-08-2013, 08:02 PM
BOBCRMAN@aol.com's Avatar
Common for numbers to be missing or smeared. Friday after lunch at the foundry.
Plugs should be old style flat gasket.
Old 04-08-2013, 08:28 PM
vinniekq2's Avatar
also consider an updated better coil for the HEI if its stock and plug gap at .040 is plenty
Unable to separate head from block due to head gasket sealer Nostalgia Hotrodding Basics 18 02-02-2011 01:12 PM
14102187 casting 305 head modification,outperform a 350 head ??? Calderone Engine 3 05-10-2009 09:09 AM
head bolts or head studs? head gaskets? thefloyd1973 Engine 9 07-04-2008 09:25 AM
Chevy head 482824?? I cant find ne listing on this head?? 89SDime Engine 3 01-27-2006 08:51 PM
More head questions for the head gurus, seen 305 heads with 2.02's 4speed57 Engine 10 07-13-2005 02:14 AM
