Build hot rod how-to articles
100+ user-created articles:
'37-'57 Buick Olds Pontiac suspension upgrade, Body-exterior tips, Bulletproof cooling system, Buying a trailer, Cheapo paint job, Cold air intakes, Cylinder head choice, Determining TDC, E85, Epoxy primer, First paint job, Free T-Bucket plans, GM transmissions, Head gasket, Header design, Health and safety, How to find an electrical drain, How to title a hot rod, How to identify a Ford V8, Make a fiberglass fan shroud, Media blasting, Patching a body panel, Pitted rust, Pre-1980 VIN decoding, Removing stuck fasteners, Rewiring a vehicle, Waterproof panelboard, Why not to use a SBC engine, and many more...
Hotrodders Bulletin Board > Tech Help > General Rodding Tech
  #1
Old 12-26-2006, 10:26 AM
MI2600's Avatar
MI2600 MI2600 is offline
Member# 3287
Name That Tool
I inherited this automotive tool from my father and I have no clue what it's for. It measures about 18" long. There is no name or numbers on it.
Ideas?
Size:  60.3 KB  Click image for larger version
Old 12-26-2006, 11:38 AM
tread40 tread40 is offline
tool name
that tool is for adjusting camber and caster on ford full size cars. locks onto upper control arm shaft and into a hole in frame to pull control arm.
Old 12-26-2006, 02:23 PM
gmaltz gmaltz is offline
re: Name That Tool
I thought it was a flywheel rotation tool, but maybe not.
Old 12-26-2006, 03:40 PM
MAUSS MAUSS is offline
re: Name That Tool
I was sure it had to be for a Ford!
Old 12-26-2006, 04:26 PM
MI2600's Avatar
Member# 3287
re: Name That Tool
Thanks, guys. I knew someone would know.
Old 01-07-2007, 05:43 PM
xntrik's Avatar
xntrik xntrik is offline
Save a horse, Ride a Cowboy.
re: Name That Tool
yes and I wish I had it, I need it
Reply Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
Similar Threads for: "Name That Tool"
Adjustment tool for TPS screw sabino56 Engine 1 11-27-2005 05:11 PM
push rod clearance tool lanierledford Engine 1 07-04-2005 07:32 PM
New Scan Tool user 36scsc Electrical 3 01-29-2005 06:35 PM
Home Mechanic's Tool Guide bigbird Hotrodders' Lounge 3 08-24-2004 09:06 PM
front end popping maddmaxx Suspension - Brakes - Steering 4 11-15-2003 07:24 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Copyright Hotrodders.com 1999 - 2008. All Rights Reserved.
