Names nate and i like fixin me some v8 chevys - Hot Rod Forum : Hotrodders Bulletin Board
Hot Rod Forum : Hotrodders Bulletin Board > General Discussion> Hotrodders' Lounge> Introduce Yourself
Old 12-02-2010, 01:42 PM
Currently looking for answers on a new project i have. its a 69 chevelle with a 400cc chevy crate motor.
It has a snaped rocker stud on the #8 cyl. not sure if its pressed or screwed in.
also looking for tips on the best process to heat around the stud to ease extraction.
THANXX
Old 12-02-2010, 03:14 PM
If it's pressed in pick up a stud remover (around $30.00 from Summit). If it's a screw in just weld a nut up on top and spin it out. You can also heat around the stud a bit with a torch and use a little WD-40.
Old 12-02-2010, 05:22 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
Welcome to the site, You really need to know what you are doing if you are going to be using a torch to remove the broken stud, If not then let someone else do the job like a machine shop or someone that has done it before.JMO
Cole
