-   Garage - Tools (http://www.hotrodders.com/forum/garage-tools/)
-   -   NAPA Floor Jack (http://www.hotrodders.com/forum/napa-floor-jack-154465.html)
mikeweb 03-05-2009 01:29 PM
NAPA Floor Jack
What do you guys think about this jack?.
Item#: NLE7916402
Its on sale at NAPA for $307.xx Canadian. Which is about $238.xx USD
Im more of a weekend mechanic so it wont be used everyday. Unfortunately we dont have a huge selection of different brands here.. just your typical Mastercraft, Craftsman, Princess Auto (Canadian version of Harbour Frieght), Michelin, ect..
http://www.napaonline.com/MasterPage...ion=Floor+Jack
Attributes:
Lift Capacity: 2-Tons
Closed Height: 2-3/4"
Raised Height: 19-5/8"
Lift Distance: 18"
Saddle Diameter: 5"
Weight:90 lbs
Product Features: Dual Pump Mechanism Which Reduces Handle Strokes Up to 50 Percent While Not Effecting Handle Effort
Nylon Wheels & Casters to Reduce Damage to Coated or Painted Floors & Reduced Noise During Transpor
Dimensions: 31" L x 16" W x 8-1/4" H
Air Operated: No
http://partimages2.genpt.com/partimages/292506.jpg
red_rider52 03-05-2009 03:46 PM
Looks like a real nice jack. If you don't want to spend that much I just bought a 3.5 ton. Michelin jack from Canadian Tire. Only $160. It reaches full hight with two strokes witch it nice, but I think most good jacks are like that now. So far I am happy with it but I only used to two times.
schnitz 03-05-2009 04:35 PM
Nice jack, but for a "weekend wrench", I'd consider something that weighs 90 lbs. My Craftsman 3 ton is too heavy on many occasions, and it's I believe around 60-70 lbs. But the final say is yours.
In a while, Chet.
grouch 03-05-2009 06:10 PM
I recently bought a 2-ton floor jack from TSC for $30.
Weight 23 lbs vs. 90 lbs for the Napa jack.
Lift range 5.25" to 14" vs. 2.75" to 19.625".
For my very limited usage, those differences were not and are not enough to justify an additional $344 for the Napa jack.
NEW INTERIORS 03-05-2009 08:15 PM
Item#: NLE7916402
Attributes:
Lift Distance: 18"
Saddle Diameter: 5"
Weight:90 lbs
Air Operated: No
I have that same jack,I use it every day,It's a very good jack,I got my NAPA man to let me have it for $200 for Christmas. :thumbup:
C-10 03-05-2009 09:40 PM
The nylon casters threw a red flag in front of me.. Seems like this would be an unnecessary risk. I am in the market for a new floor jack also to replace my old Hein-Werner, circa 1978, which lifts 1.5 tons and weighs 1.5 tons. Made in the States, however.
My new one very well could be a new Hein Werner unless somebody speaks up. :D
http://i23.ebayimg.com/03/i/001/12/47/fb42_1.JPG
"Dollars are like votes, except that they actually count."
NEW INTERIORS 03-05-2009 10:30 PM
With what I put my jack through everyday,Them wheels are like steel. :) I sure don't worry about them. :D
Rambo_The_Dog 03-05-2009 10:44 PM
I've been looking for a floor jack that had nylon wheels - now I've found one - thanks! :thumbup:
If you go to the time and expense to epoxy your floors you don't want to bung them up with steel wheels. :nono:
mikeweb 03-09-2009 01:19 PM
I ended up picking up the napa jack. Its very nicely built, hopefully it stands up.
I will say this.. at 90lbs its pretty heavy! however the nylon wheels make it easy to drag/roll around the garage, much easier then my old jacks metal wheels.. plus it makes less noise!
I also like the grease fittings that are on it :)
mikeweb 06-24-2009 12:54 PM
Well, I've been using this jack for a few months now and I must say that its serving me well.
One thing that I have noticed is that it squeaks when lifting a heavy load. Has anyone experienced this phenomenon with their jacks?
cranky1 06-24-2009 01:10 PM
Where is the jack made? In my book, there isn't a Jack made in China that's worth having...not to mention I'm sick of sending my money to a commie country and in return get crap but I have no problem buying products made in Japan or any other non commie country but I'm do my best to buy from this country if I can....but that's just me.
robs ss 06-25-2009 11:27 PM
Heres this from a while back, http://www.hotrodders.com/forum/advi...apa+floor+jack Anyway i'm still using them and they are a really nice jack.
Rob http://www.1969supersport.com
mikeweb 06-28-2009 07:22 PM
.... China :(
Mr.NutCase 07-11-2009 07:38 PM
i HATE CHEAP JACKS.......
speede5 07-12-2009 07:14 PM
I have the same jack and it is great for the weekend warrior. heavy, but works great. Affordale too. Unless you are going to invest in an alumimun race jack this would be more than enough.
