$$$ to narrow 10 bolt ? - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-03-2007, 08:33 PM
Vortech 4.3's Avatar
jack of all trades
how much, basicly, would it cost to narrow a 8.5 10 bolt, with bolt in axle bearings added. thanx
Old 09-03-2007, 08:34 PM
jack of all trades
oh. add could the original backing plate be used ? thanx
Old 09-03-2007, 09:40 PM
kc0kfg's Avatar
kc0kfg
10 bolt
Why????
If you plan on running some power to it, (I assume you are) why not start with a gm 12 bolt or better yet a ford 9 inch.
After all the ford already has the bolt in axles and the cases can be store-bought already made for many makes/models of cars/trucks.
Just my thoughts
Brian kc0kfg
Old 09-03-2007, 09:42 PM
How much are you narrowing could you get away with stock width and different backspacing on the wheels.For all the money that it'd cost why not go with a 12 bolt?
Shane
Old 09-03-2007, 10:15 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Moser engineering narrows the housing for about 120 buck$
they are located in Indiana
Old 09-04-2007, 05:56 AM
wow I thought it was around 5-6 to get one narrowed does that include resplining the axles?
Shane
Old 09-06-2007, 07:30 PM
jack of all trades
a 12 bolt would cost around $2000. a narrowed 8.5 would be around $1000. and do the same job. it would be narrowed about 6".
Old 09-07-2007, 12:18 AM
These guys have reasonable prices, got an axle etc from them, seems like decent stuff..........You can get just about any configuration you want.
http://www.quickperformance.com/Prod...ings.htm#Axles
Old 09-07-2007, 05:35 PM
heck there has baen a truck 12 bolt for 50 or 150 in the paper here.Anyone want the number if I can find it?
Shane
the history of chevy v8's savman1 Hotrodders' Lounge 43 03-02-2012 06:57 PM
10 bolt or 12 bolt???? tinman386 Transmission - Rearend 14 07-31-2007 02:03 AM
Swaping 10 bolt rear ends, what will fit? fansick Transmission - Rearend 5 07-13-2007 02:41 PM
questions about swapping R/E gears from a 12 bolt Gm into a Pontiac 10 bolt housing l Bad Rat Transmission - Rearend 6 06-11-2007 10:50 AM
10 bolt to 14 bolt rear-end conversion in 96 1/2 ton chevy 4X4??? tommytempest Transmission - Rearend 14 05-09-2007 08:19 PM
