Narrowband A/F sensor & gauge ok? - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-25-2008, 06:22 AM
staleg's Avatar
Last journal entry: Hand brake
I'm considering buying an air/fuel narrowband gauge to ensure proper tuning of the carb.
My home built hot rod is the first hot rod I've ever had. Same with the motor & the carb, so I will probably need all the help I can get.
Some says wide band is the only way to go, while others say that the narrowband sensor is of a great help too.
Any of you with experience with the narrowband sensor?
Old 04-25-2008, 07:38 AM
Wiki Edits: 31
with a narrowband your only going to see lean or rich, nothing from inbetween for how much ither way.... a cheap narrowband is only $20-30 but a cheap wideband is only $60-$80... A lot of VW's use widebands.. call 1-800 VW parts, they'll have the best price on a new 1 and maby even a good used 1.
Old 04-25-2008, 11:53 AM
If it's a matter of money then I would recommend that you wait and buy the WIDE band unit. As already explained, narrow band won't give you the info you need to tune and make changes.
You'll be wanting to run rich (11:1) for power and lean (16:1) for mileage and cruise - narrow band won't give you specific A/F ratios.
Paul
question about ballast resistor and wire gauge redneckprofessor Electrical 25 06-09-2007 01:50 PM
Guages are dead gtipton Electrical 4 05-09-2007 09:14 PM
mechanical oil gauge bleeding? cboy Engine 5 06-28-2005 04:37 PM
Need help with fuel gauge Crazy-J Electrical 3 03-01-2005 11:46 AM
Twilight Zone and my temperature gauge unstable Engine 8 10-08-2003 03:57 PM
