narrowing ford 9 in - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-03-2006, 12:43 PM
narrowing ford 9 in
im building 1930 model a closed cab pickupstreet rod not sure how much to take off each tube also using disc brakes on rear
Old 09-03-2006, 03:56 PM
Well ... it depends on the backspacing of the rims you plan to use and IF you are planning on fenders ... also how wide the rear is that you already have ...
Most Model A's work out best if the distance ( measured like shown above ) is 56 to 58 inches. 56 works best ... for me ...
A early Bronco ( 66 to mid 70's ) is 58 inches ... measured that way ... stock ... and a 57 to 59 Ford passenger car rear is 58 inches wide ... measured that way.
M.S. requested joke thread hotrodit Off-Topic 187 08-31-2014 06:14 AM
All right all you Ford guys, a couple of questions Shades_o_Grey General Rodding Tech 8 12-28-2010 06:00 PM
Ford Steel Wheel Tech wheelkid General Rodding Tech 9 01-07-2007 06:31 PM
Ford Alternative Restomod Article datson280zxturbo Hotrodding Basics 1 05-31-2006 03:18 AM
Transfer case - NP 203 - 205 jrm123180 Transmission - Rearend 2 03-24-2006 07:36 AM
