Narrowing a Ford 9'' rearend
Does anybody have any info about narrowing a Ford 9" rear. I know can get new housing ends at www.mittlerbros.com/rearend for $60 a pair; I'm concerned about alignment issues. I believe I can get a square, straight cut on the housing using a large tubing cutter. I've seen this done using nothing more than a long piece of threaded rod and two pieces of 1/4'' plate to clamp everything together. Will the alignment provided by this method be acceptable,or, "good enough"? Does anyone know of a company in northern CA or San Francisco bay area that can re-spline axles? One last thought, I have several rearends to play with, this will give me the opportunity to center up the pinion, if I can do this are there any advantages/disadvantages. Thanks in advance, Dave 39
To get everything properly aligned you need a 1 1/4 or larger solid steel bar and bushings that fit inside the bearing caps on a bare center section with bushings that fit the bar and the inside of the bearing ends. You dont need new bearing ends i worked for a rearend place and unless a person wanted new ends we used used ends all the time.I used to work for www.quickperformance.com
| ford rearend in a chevy | jo5hi3 | Transmission - Rearend | 2 | 12-06-2003 11:11 AM |
| Ford 9" Rear End Narrowing | nightrain_rod | Transmission - Rearend | 3 | 11-30-2003 11:50 AM |
| Ford 9 inch rearend | Nos | Transmission - Rearend | 2 | 05-21-2003 07:39 AM |
| 40 ford rearend | 49burb | Transmission - Rearend | 7 | 05-19-2003 11:53 PM |
| ford rearend for 33? | nick | Transmission - Rearend | 2 | 11-06-2001 10:58 PM |
