Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - narrowing rear end
Old 08-01-2010, 01:32 PM
big gear head's Avatar
big gear head big gear head is offline
High Performance Rear Ends
The pinion offset on all Chevy car rear ends is 1/2 inch to the right of center. I'm pretty sure that the Bronco has more pinion offset than that. Many people are using the Explorer 8.8 rear end in their projects, which has a lot more pinion offset than 1/2 inch. The drive shaft doesn't line up with the tunnel in the floor. Just check the pinion offset in a stock Bronco rear end and try to keep it the same on the new rear end.
