Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - narrowing rear end
Old 08-02-2010, 08:03 PM
77bronco_ed's Avatar
77bronco_ed 77bronco_ed is offline
Originally Posted by big gear head
The pinion offset on all Chevy car rear ends is 1/2 inch to the right of center. I'm pretty sure that the Bronco has more pinion offset than that. Many people are using the Explorer 8.8 rear end in their projects, which has a lot more pinion offset than 1/2 inch. The drive shaft doesn't line up with the tunnel in the floor. Just check the pinion offset in a stock Bronco rear end and try to keep it the same on the new rear end.
OK... I'll keep the pinion offset location to original rear.
I am getting excited, still wrapping up my 4x4 Bronco and already rolling into next project.
74 waiting in line...
Prostreet similar to look I am going for but... I want to chop the top and only have a slight rake.(Keep quarters as original)
ID:	47149   Click image for larger version
ID:	47150   Click image for larger version
