Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Project street rod Bronco
  #38 (permalink)
Old 06-28-2011, 08:14 PM
77bronco_ed's Avatar
77bronco_ed 77bronco_ed is offline
I have frame rails tacked together and clamped in place.
Rear end already has multi hole brackets welded @ angle for shocks.
Pivot points need to be parallel but what determines shock length?
Once the cross bar is located I can simply measure for shock length.
cross bar placement is based on? Amount of room? easiest place to locate?
Is there a preference when it comes to length for shock? stay away from a particular minimum or maxium length. I have a little flexibility in where I mount a crossbar for upper shock mounts. Should I try to fit the largest length shock possible. (Just tossed in another photo, starting thinking amount of chop before I went on vacation. 7" chop of mock up window frame.)
Thanks
ID:	56428   Click image for larger version
