Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Narrowing the rear end
Old 08-23-2004, 10:14 AM
brainsboy's Avatar
brainsboy brainsboy is offline
brains
One thing to keep in mind also is to allow space for a fuel cell, im not sure if you will use one, but the last frame I modified I left enough room for a fuel cell to fit inbetween perfectly. You want to use standard offset rims, dont have the offset maxed out, so if you want to change rims later they wont stick 3inches too far out or in. It helps to choose what type of braking system your going to use in advance, as some rotors will be thicker then others.
Ben
