Narrowing a Rearend. - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-22-2009, 05:54 PM
I viewed the "narrowing a rearend" article and found it to be very interesting. It did not appear to discuss the axle shortening so can anyone direct me to that information ? I am in the process of 4-linking my 1951 Austin Gasser and the rear axle narrowing is my next step. Any thoughts or advise is very welcome .
Old 08-22-2009, 06:40 PM
BOBCRMAN@aol.com's Avatar
Narrowing/re-splining of the shaft gets a bit complicated and requires specific equipment.
Back in the day. I used to re spline my own narrowed 9" Ford stuff. The axle shaft has to have enuff material to rough turn to OD. Then the proper cutter is required, with an indexing fixture and a fairly powerful mill. I used a common Bridgeport with "J" head. Takes a bit of time to cut TUFF axle material.
Thats why when aftermkt began offering the service (Currie, Moser, Johns etc.. I sent the axles out and just did the housings.
Old 08-22-2009, 06:46 PM
Rear axle shaft.
So are you saying the axle is not cut and re-welded ? Does it need to be cut to length and then re-splined ?
Old 08-22-2009, 07:09 PM
prostreet6t9's Avatar
Differential/Driveline
Yes! it will need to be cut and resplined.Thats why it's important that the axle has enough material at the cut point.
Old 08-22-2009, 07:20 PM
Rear axle narrowing.
My axles are old strange engineering axles so would they do that or is there other alternatives ?
Old 08-22-2009, 09:20 PM
If they're Strange axles you should be able to shorten and respline them. The axle's should be the same diameter all the way down.
Old 08-23-2009, 11:56 AM
Shortening Axles.
Once you have the rear axle housing narrowed, how do you determine the length that the axles need to be shortened ?
Old 08-23-2009, 02:51 PM
I measure from the inside of the side gear to where the axle brg seat's in the housing end. So After the housing is done,I will drop the center section in and measure. It's probably best to talk to whoever is gonna shorten them for you, and measure how they want. That way was there is no screw ups.
Old 08-23-2009, 07:22 PM
life is a temporary assignment
If you call here http://www.moserengineering.com/ They will ask you a few Question's, just give them the answer's. And send them about $475.00 and you will get two brand new axles and bearing's and studs.No problem's..
They will want to know if it's a 9'' and will want the flange to flange measurement.And want to know if the pinon is centered..And will want to know what brake's you will be using,and a few other things..
Old 08-23-2009, 08:51 PM
http://www.dutchmanms.com/pricesheet.html#Anchor-65123
There is another option for $100.00 cheaper. Both are great quality stuff.
Old 08-23-2009, 10:37 PM
camaroman7d's Avatar
I agree why bother with re-splining? I might think about it if theaxles were aftermarket (as in this case). No way I would bother with stock axles.
You need to figure out your track widthbefore cutting the housing. you can't really do that if you don't know your axle offsets.
Old 08-23-2009, 11:03 PM
I like buying new axles from Moser,,Very nice axle's..First class..I had only one problem,With one of their axle..When I installed the axle in my housing,It got two hard to turn,Pulled it out and cut about 1/16 off the end,Put it back together,No more problem..
Man I love that car you have camaroman...My first car was a 73..And was about the same color..I hope to find one,So I can build it just like my old one..
new wiki article: Narrowing a rearend; thanks Centerline Jon Transmission - Rearend 0 06-12-2008 04:37 PM
Narrowing a C5 rearend HRC Transmission - Rearend 4 05-31-2008 08:25 PM
Narrowing a Ford 9'' rearend Dave 39 Hotrodding Basics 1 07-21-2006 04:17 AM
Hotrodders Knowledge Base: Transmission - Rearend Jon Transmission - Rearend 0 11-26-2005 07:23 PM
Building a rearend narrowing alignment jig. F-1Rodder Transmission - Rearend 3 02-20-2002 02:53 PM
