Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Narrowing Rearend for G body
Old 01-21-2013, 11:02 AM
S10xGN's Avatar
S10xGN S10xGN is online now
Gotta love a turbo!
Originally Posted by zildjian4life218 View Post
To get the correct pinion offset I have to take some metal from one side and add some to the other. I was just going to have new axles made since I believe the two short sides or two long side axles was either too much or not enough and since the splines are rolled I believe that they would have to cut them back too far for me to be able to use the long side axles. I will have to double check that, I just remember looking into it before and it seemed like no combination of the axles would work.
Guess I wasn't thinking about your overall width, mine worked out perfectly. You may be able to make it up by juggling your wheel offset. Those axles cannot be resplined, so you'd need (at least) one new axle...
Russ
