nason - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-02-2012, 09:20 PM
nason
hi, this is my first post here, but i love reading this forum. did a project in nason ss low voc solid color, and need to blend a couple small areas. i have blended many times in the old days with sw acrylic enamel and rm miracryl. but not with this stuff. is there anything to watch out for. any help would be appreciated. thanks
Old 07-03-2012, 05:34 PM
deadbodyman's Avatar
Wiki Edits: 11
I'm not sure if i understand you right but any time you blend a SS you have to clear just like blending a base .Now if you mean "burn" the paint in thats different. burning or "melting" the edges in is pretty tuff to do and almost impossible with the darker colors...you'll have to be a little more specific about the SS,nowdays when you say "SS" everyone thinks Urathane ,nobody really uses acrilic or straight enamels any more because the urathanes hold up a lot better and cost about the same.... I guess the most important question I can ask is: Did you use a hardener when you painted the car? Nason still sells enamels that dont require a hardner...
Old 07-04-2012, 09:49 AM
i used nason low voc fulthane single stage. i wasnt sure if a solvent blend was doable. it has a hardener
Old 07-04-2012, 10:41 AM
swvalcon's Avatar
Last journal entry: rust on lt body shell
If you have done bends on old acrylic enamel you should have no problems with the newer stuff. I still do my blends the same it's just a little harder to blend out so leave your self a lot of room. Or as deadbodyman said scuff blend and clear coat your panel.
Old 07-04-2012, 12:08 PM
thanks , il give it a shot
Nason Metallic Help jeetkunedoground Body - Exterior 2 06-20-2010 06:34 PM
Wanting to change from Nason ful-thane 2k urethane to Nason basecoat/clearcoat Jobo62 Body - Exterior 3 12-18-2006 08:45 AM
Nason 3:1 vs. 4:1 clear firechicken383 Body - Exterior 10 09-09-2005 10:38 AM
Dupont Nason JLarson69 Body - Exterior 15 07-07-2005 10:52 PM
Need help with nason paint! amanderson Body - Exterior 2 07-05-2005 09:33 AM
