Nason 2k primer - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-18-2005, 08:25 PM
Nason 2k primer
Ok I went to the local Dupont dealer and asked for a urethane primer to be used over epoxy primer and I was sold Nason Slect Prime 421-20 primer surfacer which is indeed a two part primer but when I checked the product data sheets for Nason I find that they have Select Prime 421-19 2k and 421-17 2k listed as urethane primer but the 421-20 is listed simply as primer surfacer? Is it urethane? The paint salesman says it is but I am not sure as the data sheet does not say. What is the diffrence here? According to the data sheet it looks like it will do what I want but I have sprayed it over 12 hr cured unsanded epoxy and I need to know if this is ok as the data sheets dont say.
Old 04-18-2005, 09:15 PM
Last journal entry: metal finish
it will work just fine.
Maaco vs. At-Home Paint Job nightrain_rod Body - Exterior 127 08-26-2012 03:07 AM
Bare Metal Mollard Body - Exterior 71 09-25-2008 01:48 PM
"Basic of Basics" What kind of paint should I use? Centerline Body - Exterior 5 10-21-2007 11:32 PM
"Basic of Basics" What are the new paints all about? Centerline Body - Exterior 0 07-26-2004 06:43 AM
2k Primer scraping off? Need help misteryu Body - Exterior 1 07-17-2004 04:55 AM
