Nason 3:1 vs. 4:1 clear
How does Nasons 497-00 clear (3:1) compare with the 496-00 clear (4:1)?
I have used the 496-00 before with success and really liked it. The 497 clear says "panel and overall clear". The 496 just says "clearcoat" Is 1 better than the other? Thanks |
As a rule of thumb the lower the mix ratio the better.. Example: you will find your cheapest clears from your major companys mix 4:1.... This does not mean they will not spray well or look good when done, but for the most part in this industry.. you get what you pay for with some exceptions to the rule here and there (SPI being one of them)... Ok as you buy better clears they will mix 3:1, 2:1, and 1:1...
I do not have experience with Nason clears, however I would venture an educated guess the 497 is def. better... Someone else can chime in with more details.... BK |
Im pretty sure the 496 is there faster curing clear..
BTW I have used ppg concept clear, sherman williams/martin senior, American Fisnishes ( ownded by ppg) Evercoat used to make one I used, sikkens etc... I cant remember them all but I have used enough of them to form a good opinion I think BK BK |
I've been using the 497 lately and really like it. Great clarity and flows well but you may need to up the gun PSI a bit to get if flat. Be sure to use the correct catylist for the temp you shooting at. It dosen't have the gloss IMO the Chroma series has,that super wet look,but is way cheaper and will do you proud.A good cut and buff will really make it shine. Get an extra can of catylist too as at a 3:1 mix it dosen't work out right and you'll have extra clear left over.
It's SHERWIN WILLIAMS, not sherman. |
68ss, IF it's just pop in the clear,you need not go that far. I'd sand the clear first lightly with some 600,either wet it with the 50/50 alc.water or grease & wax remover and SEE if they are gone before taking it all the way down to paint.
I had some solvent pop over some black I shot on a graphic touch up and cleared a little too soon and the clear was bubbled up all over that black,I color sanded with 600 and recleared a couple day's later and it turned out beautiful. FWIW. Mike. |
bee4me
Mike,
I wish it was that easy. It looks like the craters go all the way to the base coat. to make matters worse i was goofing off with it right before i deployed and hit a mailbox on the passenger door. God my wife was HOT. so i have to replace a door at least and then deal with the paint issue. if it wasn't for replacing door's i would try that. Thanks Toby |
| Clear, No Clear, or Clear + Base? | tallpaul | Body - Exterior | 16 | 01-21-2006 05:30 PM |
| Wetsanding Clear and Metal Flake on Edge | Phillip27 | Body - Exterior | 11 | 01-20-2006 02:52 PM |
| SPI HS clear, what is the difference between the 2 | BondoKing | Body - Exterior | 0 | 05-24-2005 03:18 PM |
| New Paint, Clear Scratches real easy?? | syclone477 | Body - Exterior | 11 | 03-20-2005 08:08 PM |
| Which type, base coat clear coat or.. | Rubberman2003 | Body - Exterior | 20 | 12-19-2003 01:09 AM |
