nason 412-08 acrylic lacquer - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-11-2006, 08:32 AM
55paneltrk.'s Avatar
The nason 412-08 is this okay to use if i'm going with a bc cc
I have been using it over my epoxy primer
thank you for your time
Old 07-11-2006, 08:40 AM
roger1's Avatar
Nah.
All lacquer primer is old technology and should not be used anymore.
Use a 2K urethane primer. Or, if you need a really high-build, use a polyester primer.
Old 07-11-2006, 09:09 AM
This has been discussed a bunch and I think everyone (almost everyone anyway) agrees that there is just no real use for the stuff anymore except maybe as a guide coat. If you do a search on lacquer primer I think you will find all kinds of negative input.
From just a few days ago.
Body done in lacquer primer
Old 07-11-2006, 11:03 AM
Hey thanks, now from what i read on some past lacquer threads i need to sand off the lacquer primer and do it right.
since the only auto paint supplier around is dupont, can any one tell me what is a good high build sanding urethane primer that they have
Old 07-11-2006, 12:20 PM
roger1's Avatar
You might think about ordering primer from Southern Polyurethanes Inc. http://www.southernpolyurethanes.com/
Their products are very well liked on this forum.
Old 07-11-2006, 04:44 PM
Since you have a Dupont dealer you probably have access to Nason so if cost is a big factor you might want to check out the Nason 421-20.
Old 07-12-2006, 08:33 AM
Thank you OldRed, No, cost does not matter I just want to do it right. I used epoxy primer first, then the paint store got me using the acrylic lacquer I don't know what happend, they knew I was going with a bc cc. Anyway I only got just 1/2 way with the lacquer primer.
So tell me is the Dupont, Nason epoxy primer that I used going to be okay?
thank you all for your time.
Maaco vs. At-Home Paint Job nightrain_rod Body - Exterior 127 08-26-2012 03:07 AM
Why lacquer paint markl Body - Exterior 5 11-06-2005 08:12 PM
Acrylci Enamel Acrylic Lacquer boofis Body - Exterior 17 01-02-2005 05:53 PM
Which type, base coat clear coat or.. Rubberman2003 Body - Exterior 20 12-19-2003 01:09 AM
Coincedence or not?????? Kevin45 Hotrodders' Lounge 23 11-13-2003 09:23 AM
