Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - nason clear problem
Old 07-14-2010, 05:52 AM
deadbodyman's Avatar
deadbodyman deadbodyman is offline
Wiki Edits: 11
clear drys differntly under different conditions so the way I know when to apply the next coat is to touch the paper where the clear hit it should be slightly tacky but not dry and not wet to where it will slide or make strings wnen you lift your finger off ...bubbles are a whole differnt problem then lifting,without any pics I would try to lightly sand them out with 600 and then lightly scuff the entire panel with 600....This wont work if the base is lifting but if its just the clear it should work. since it sounds like a water problem ,do you have any filters from your compressor to the gun??? even a small 5.00 gun filter might solve the problem...
