Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - nason clear problem
Old 07-14-2010, 06:17 AM
deadbodyman's Avatar
deadbodyman deadbodyman is offline
Wiki Edits: 11
Its ready to sand...I think you'll be ok this time...heres a way to see if you have any water first drain your tank.then let it build up to max pressure crank your regulators up to wide open,stick an air nipple in the hose and let her rip if theres any water you'll see it or hold the nipple against some glass about a 1/4" that'll show you too.
BTW,I never leave the booth when I'm clearing it only takes two coats ,in this heat theres only a 5 minute wait between coats..
