nason ful fil primer - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-06-2006, 06:15 PM
hey guys can i use the nason ful fil primer over small bare metal spots with out putting a sealer on it first. and also do I need to seal it after the last primer coat before i paint? newbeeeee.
Old 01-06-2006, 07:36 PM
yes if spot is smaller than a half dollar and no you don't need sealer if you don't break through sanding
Old 01-06-2006, 10:47 PM
Bee4Me's Avatar
Problem Child,Hard Case
Last journal entry: Strangest job I've ever done
I think Frank meant larger.
If it's just cut thru's,Don't sweat it.Shoot some over and block them out like usual.
Sealer is not necessary and IF i can can keep from using it,I won't.
I've had MORE trouble shooting over sealer than a 2k than I care to comment on. I hate the stuff personally. Kinda like adhesion promoter, If you use the right product to begin with,you don't need "coatings".
Maaco vs. At-Home Paint Job nightrain_rod Body - Exterior 127 08-26-2012 04:07 AM
Epoxy vs Urethane Primer UKLuge66 Body - Exterior 41 11-23-2008 06:50 PM
Nason Epoxy Primer?? 67goat Body - Exterior 7 08-21-2005 12:23 AM
Nason 2k primer oldred Body - Exterior 1 04-18-2005 10:15 PM
good primer over ok primer hoss Body - Exterior 1 09-17-2003 02:28 AM
