Nason Metallic Help - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-17-2010, 10:44 AM
jeetkunedoground's Avatar
Newbie
Nason Metallic Help
Hello Everybody!
Im working on a BMW hood
My problem was when applying my first streak of paint my second streak started to dry forming little tiny dust balls after curing felt like sand paper i'm guessing , dry spots!
Temps were around 77+ and i was using standard nason reducer, so i picked up nasons slow reducer and started a second run.
first streak was wet, second wet as the first now the 3rd was another story becuase first and second were drying before my eyes
to make the story short i used more paint then i expected to cover everything thanks to the forum i remembered somebody mentioning the drop coat technique which made everything even.
all in all everything turned out great expect for the inexperience i have. i want to make sure i dont have this problem again !
thanks in advance
mike
btw do u think the sata rp 3000 would of kept it wet due its repuatation to keep things wet haha
Nason oreinted blue matallic
Nason reducer slow
Gun: iwata lph400
Needle 1.3
pressure 16-18
distance 4-6 inch
temp varied high 70+ to low 63
Old 06-18-2010, 12:16 AM
lph400 is a slower paced gun, but i wouldnt think you are moving that slow to have paint drying before your eyes.
Maybe you are putting to thin of a coat on? Are you getting actual streaking with the metallic paint?
Old 06-20-2010, 06:34 PM
Newbie
hello
When i mentioned streak as in 50% over lap but i couldn't because the wetness disappeared , my gun pace was close to 3 to 4 seconds per foot.
Metallic Chromabase questions Noob81 Body - Exterior 13 04-15-2010 03:10 PM
Nason Clear coat GS 455 Body - Exterior 5 03-25-2010 01:34 AM
Dupont or Nason BC/CC? ScotY Body - Exterior 10 01-31-2009 09:16 AM
Nason Ful-Poxy over sandblasted steel? Greg9504 Body - Exterior 15 10-15-2008 02:56 PM
Which type, base coat clear coat or.. Rubberman2003 Body - Exterior 20 12-19-2003 01:09 AM
