nason over ppg help - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-18-2003, 06:34 AM
nason over ppg help
i used ppg k-36 primer can i go over it with nason bc cc help
Old 10-18-2003, 07:18 AM
302 Z28's Avatar
Can't say for sure, but my guess would be yes. K36 is some premium primer/surfacer/sealer. I am not familiar with the Nason brand of BC/CC.
Vince
Old 10-18-2003, 11:06 AM
jwart's Avatar
i agree with overdose popably ok. do a test panel with color on it with wet coats, but don't think your done as you have to do clear on color as sometimes its the catalyst in clear that raise paint - primer. jwart
Old 10-18-2003, 11:44 AM
hey overdose, i just used ppg k36, you should be fine, if you read the tech sheets nason base requires the nason sealer for a uniform appearance, i never skip that step, hope that helps
Old 10-18-2003, 03:46 PM
where can i find tech sheets for nason
Old 10-18-2003, 07:37 PM
adtkart@aol.com
Check your local Dupont/Nason dealer or the Dupont web site.
Old 10-18-2003, 07:58 PM
IT'S MY JOB...
Over Dose, If you cannot find the TDS sheets on anything you are going to spray, PM me and I will get them to you. Bryan.....
Old 10-20-2003, 08:02 PM
thanks all for the help guess i will go with ppg to be on the safe side Dwayne
