nasty grinding noise - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-20-2007, 10:14 PM
howdy i have a problem. i have a 99 firebird and when i try to go in reverse it makes a awful grinding noise. now here is the thing. if i go into to first before i go into reverse it wont make any noise at all. so i would like to know if anyone knows what maybe causeing that to happen when i go into first then reverse no noise but straight into reverse nasty noise.
thanks
Old 07-20-2007, 11:08 PM
Jmark's Avatar
Most likely you need to atleast adjust the clutch. It's not dis-engaging the pressure plate all the way. The reason it doesn't do it when shifting from the forward gears is they have syncros and stop the disk from spinning before going into gear, reverse has no syncro.
Adjust the clutch and it will probably be fine.
Mark
Old 07-21-2007, 12:03 AM
oh ok thanks.
Old 07-21-2007, 08:32 AM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
I am curious if this Firebird has a hydraulic clutch....? These are not usually adjustable.
IF that is the case, i'd look for leaks, old - dirty fluid, spongey feeling pedal?
700r4 2-4 grinding noise AngliaBob Transmission - Rearend 1 05-14-2006 05:21 PM
Awfull grinding noise follow-up... TVR383 Engine 4 05-24-2005 07:36 PM
grinding noise (awfull..) TVR383 Engine 7 05-23-2005 08:39 PM
Grinding noise yogunna123 Transmission - Rearend 0 09-30-2003 05:45 PM
th-350 clanking noise then grinding the nothing roadrash9r Transmission - Rearend 8 12-09-2002 03:32 PM
