Need 10-bolt ID help - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-23-2010, 07:02 AM
Last journal entry: Dash install completed
I just got a 1974 10-bolt posi out of a Firebird that is going to go in my 48 Chevy Sedan Delivery hotrod. The axle tube code is CM so I think this is a 3.42 gear. The numbers on the ring gear are GM 3984828 13 40 11 73. I think this is November 1973 build date (rear end casting date is September 23, 1973), but what is the tooth count or ratio on the ring gear?
The pinion code is GM 1 11 73 3984829. What does that tell me?
Thanks guys.
Bear Lake Rodder.
Old 11-23-2010, 07:19 AM
T-Bucket, Corvette, Mustang
Looks like you have a 40 tooth ring gear mated to a 13 tooth pinion for a 3.08 ratio. However, since you can see the numbers on the ring gear, why not mark a tooth on each gear and count the teeth to be sure?
Old 11-23-2010, 08:00 AM
Thank you for the info. The seller said it was a 3.08, but the axle tube code is 3.42. Must have been switched at some time in its life. Surprise!
Bear Lake Rodder
Old 11-23-2010, 09:38 AM
big gear head's Avatar
High Performance Rear Ends
Yea, that's a 3.08 gear made November of '73.
"Basics of Basics" Rusted bolt in caged nut removal. MARTINSR Hotrodding Basics 3 11-11-2010 10:56 AM
10 bolt or 12 bolt???? tinman386 Transmission - Rearend 14 07-31-2007 02:03 AM
Swaping 10 bolt rear ends, what will fit? fansick Transmission - Rearend 5 07-13-2007 02:41 PM
10 bolt or 12 bolt rearends ? a62chevy Transmission - Rearend 5 09-21-2003 05:16 AM
converting GM 10 bolt to rear disc brakes, have questions HotRodF100 Suspension - Brakes - Steering 7 09-18-2002 11:22 AM
