Need 350 sm blk chevy help - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-04-2006, 02:16 PM
alright im pitting my small block 350 together 2 questions
does the dome of the piston go on the cam side of the cylinder or the exhaust and the rods do the numbers go to the outside of the block or inside thanks
Old 03-04-2006, 02:52 PM
DoubleVision's Avatar
the dome always goes to the exhaust side, if it was the other way around it would hit the quench pad of the head so they can only work one way, if a piston was at top dead center with the dome wrong you couldn`t bolt the head on. The numbers go to the outside, the locks on the rod bearings always point to the outside of the block. But honestly, and no disrespect intended here, If you didn`t know the answers I think I`d learn more before I jumped on rebuilding it.
Old 03-05-2006, 07:56 PM
just makeing sure i built my fair of ford and first time putting dome pistons in easy to ask then make a mistake
thanks dave
Old 03-06-2006, 08:25 AM
[QUOTE: But honestly, and no disrespect intended here, If you didn`t know the answers I think I`d learn more before I jumped on rebuilding it.[/QUOTE]
I was thinking that same thing before I even read your reply, but I thought it sounded rude (you put it very politely though ). But if you ARE going to build it, take your time and go slowly and double (or tripple) check EVERYTHING as you go
finally finished chevy 350 build redneckrodder Engine 7 05-30-2011 06:03 PM
El Camino Engine - 350 Chevy or 455 Pontiac bjam2 Engine 16 08-07-2007 03:45 PM
96 chevy 305 vortec heads on 350 block badriand Engine 6 02-20-2006 07:45 AM
engine cooling specs for 350 4 bolt chevy downunder Introduce Yourself 2 10-02-2004 10:41 PM
85 chevy 305 heads on an 89 TBI chevy 350? jazzguitar Engine 4 11-03-2002 04:11 AM
