Need a 4.5" I.D. Stainless 90 where? - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-17-2013, 08:28 PM
1930u's Avatar
Last journal entry: 1930u Its just been sitting
I need two stainless steel, 4.5" I.D., 90's or one, 4.5", I.D., 180 bend to make turn outs for my side pipes. It's an odd size and I have had no luck finding them.
Any thoughts?
Thanks,
1930U
Old 03-18-2013, 06:40 AM
delawarebill's Avatar
4 1/2"
i did a fast google and i'm feeling u'r asking alot.. there is 4 1/2 od in a tubing. there is some places on ebay u may call and ask. just search it and find a supplier then call... sorry..
Old 03-18-2013, 01:21 PM
DERPR30's Avatar
just find a pipe fitting supplier 4/1/2 od is just 4 in pipe size 90 s are cheap but a 180 bend is very expensive
Old 03-19-2013, 06:51 PM
1930u's Avatar
Thanks guys.
Old 03-19-2013, 06:59 PM
lakeroadster's Avatar
Hot Rods are Built, not Bought
Last journal entry: Lakeroadster's '31 Model A Tudor
4-1/2" i.d. is a strange size. 4-1/2" o.d. elbows are available from the following:
Old 03-21-2013, 06:36 PM
1930u's Avatar
Thanks for the info. Here's some pics of what I'm into...big block chevy headers adapted to fit a 392 Hemi. The collectors are 4.55" OD. I made the side pipe tubes from stainless sheet stock. They came out perfect and if I can just find or fabricate a turn out I'm good to go. The wall thickness is also an issue. I need like .050"-.060.
Thanks again for the info.
ID:	72462   Click image for larger version
ID:	72463   Click image for larger version
ID:	72464   Click image for larger version
Old 03-22-2013, 07:21 AM
Banned
nice ride, But that motor is Killer. Good luck with the turn outs.
Old 03-22-2013, 11:24 AM
evolvo's Avatar
Burns stainless has 4.5"OD 90's part # LB-450-45-16-304
Your Price: $118.58
Quantity:
LB-450-45-16-304
L-Bend, 4.5" OD, 4.5" CLR, 16g., 304 SS
Find Custom Exhaust, Header Collectors, Race Mufflers & More | Burns Stainless
I found them in the 304SS section. They are 4.5" OD , but to me that means you could slide it into your side pipes and weld or clamp in place. Probably look OK...........
Old 03-22-2013, 06:52 PM
Originally Posted by lakeroadster View Post
Your Price: $118.58
Quantity:
LB-450-45-16-304
McMaster Carr = $33 each
Grainger = $58 each
Burns Stainless = $118 each
What am I missing here?
Old 03-22-2013, 07:50 PM
1930u's Avatar
Grainger = $58 each
The Grainger and McMaster pieces are heavy wall like schedule 40 much to heavy but the Burns 90 wall thickness may work.
Thank you all !!!!
1930u
Old 03-22-2013, 08:09 PM
Thank you all !!!!
1930u
The Grainger and McMaster are in fact .120 wall, which is sch. 10s. Sch. 40 is .237 wall. Refer to a pipe wall thickness chart :-)
Thank You 1930u!
Old 03-22-2013, 09:23 PM
1930u's Avatar
someone emailed me this place too... looks like this is what I will use for $77.00.
Stainless Steel Elbows: 180 Degree U Mandrel Bends - Verocious Motorsports
This is a great forum... thanks to all. 1930u
Strange thing happening with my clear "solvent pop"/"fish eyes" ? myfamiliacc Body - Exterior 35 02-16-2013 07:18 PM
Covering stock "plastic" door panels with "vinyl" csilva84 Interior 1 10-05-2007 06:30 PM
wiki pages: "How to rebuild an engine", "Window removal/installation" Jon Hotrodders' Lounge 0 07-11-2006 12:44 PM
EV-8 stainless steel valves "HELP" 406 ss monte Engine 5 12-17-2004 02:34 PM
Hey croz look """"IMPORTS SUCK""" 78 monte Hotrodders' Lounge 14 08-30-2002 01:13 PM
