Need 4.5" pitman arm drop for Vega steering box - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-08-2012, 07:16 PM
Last journal entry: 1947 Studebaker Pickup M-5 Completed
I installed a new Vega steering box and need a pitman arm with a 4.5-5' drop to make the tie rod connection on the drag link. There is not enough room to move the box lower, I have it located as low as possible.
Are there any other pitman arms the will fit the Vega 5/8-36 spline shaft ?
This is on a 1947 Studebaker pickup M-5.
Old 04-13-2012, 06:22 PM
LATECH's Avatar
I think a drop that large would create a big problem as far as stability.
I tried to look at your build (pretty cool BTW) to see how your steering / suspension is setup. Couldnt get a real good view, but i saw you are going to use the leaf springs on the front?and a straight axle? Could you post a few more shots of the front suspension and steering arrangement?
Cool...Later
Old 04-13-2012, 09:38 PM
pitman arm
The old Studebaker pitman arm has an @ 3" drop. I also re-evaluated the steering box and I think it can be lowered just a bit more to reduce the pitman arm drop.
I'll try and add more photo's of the suspension tomorrow.
Thanks for the reply....
vega steering box and pitman arm swanson1930 Suspension - Brakes - Steering 1 03-13-2012 07:08 AM
4" drop pitman arm for 85 chevy 3/4 ton punk1c5040 Suspension - Brakes - Steering 1 01-01-2007 05:04 PM
vega steering pitman arm question 29modela Suspension - Brakes - Steering 2 11-02-2006 11:09 AM
vega pitman arm 31fordrd Suspension - Brakes - Steering 1 10-03-2003 08:34 PM
Vega pitman arm Lash Suspension - Brakes - Steering 1 01-10-2003 04:07 PM
