Need 454 Motor Mounts for 1968 C-10 Truck - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-04-2011, 07:51 AM
454Dave's Avatar
The 454 in my recently acquired 68 C-10 is currently supported by motor plates at the forward and aft ends. I'm interested in removing the motor plate setup and converting to a more conventional motor mount setup. Not interested in a dropmember setup as the truck already sits low enough. The transmission is a TH400 and also has long tube Hooker headers. The frame rails are original, but have been notched on the drivers side for header clearance. The lower cross member (below the engine) that joins the frame rails and front suspension is also original. Any suggestions are much appreciated, thanks!
Old 02-04-2011, 05:23 PM
1971BB427's Avatar
The mounts for a C10 with small block Chevy work fine. You don't need them for a C10 with big block. Check your local truck wrecking yard or Craigslist.
Old 02-04-2011, 10:55 PM
454Dave's Avatar
Hi 1971BB427, Thanks very much for the reply!
MOTOR MOUNTS (Engine Mounts) PackMule General Rodding Tech 2 08-28-2009 10:52 AM
57 Chevy truck motor mounts djotis Engine 1 08-14-2009 12:41 PM
Motor Mounts For Camaro Clip In '57 Chevy Truck tmeyer Suspension - Brakes - Steering 5 07-20-2006 06:13 PM
chev truck motor mounts fezz-man Engine 4 12-31-2005 12:39 AM
1968 390 motor cordellryan Engine 6 03-05-2003 10:45 AM
