Need '67 Toro TS switch - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-09-2011, 12:21 PM
I NEED a turn signal switch for a '67 Toronado. I appears that they only used this style a couple years. Anyway the problem is, the brake lites...... the brakes come in to the switch , but don't come out. Also the same with the 4-ways,,front work , no rears.. Acouple years ago, I had the switch apart, and I recall removing the rivet where the contacts are, repairing something in side there. Problem with that is... theres not much left of the rivet to do it again. I assume that's where the problem is again........ I know some of the Riveira parts are same, ...........so far, I seem to locate one .........thank you
Old 02-09-2011, 01:17 PM
richard stewart 3rd's Avatar
Last journal entry: 351W rebuild
Hi.
You might try at the link.
Rich
http://www.yearone.com/serverfiles/f...tich&SM=1&SC=3
Old 02-09-2011, 07:19 PM
no luck there either....anyone got a used one, maybe for parts ?
Old 02-10-2011, 08:22 AM
Originally Posted by richard stewart 3rd
Hi.
Rich
The only parts for a Toronado available from Y1 are those that are common to the Cutlass/442 cars.
Have you tried Fusick? They have a dedicated Toro catalog.
Old 02-10-2011, 08:59 AM
no luck there , either, the tilt and tele is the difference.........besides the man from Fusic was a real jerk, I threw his catalog magazing in to the garbage, along with USA Parts !
Old 02-10-2011, 09:14 AM
That's surprising. In any case, a 67 (and possibly 68) Eldo tilt/tele column should be the same. You might want to try a Caddy resto supplier.
Old 02-11-2011, 08:32 AM
Hi,
Here's a couple of switch's, & if the ones shown aren't
correct, they may have a used one in their yard.
Rich
http://www.usedpartslive.com/catalog...le&md=Toronado
Old 02-11-2011, 05:09 PM
nope. all three are for the reg or standard column. The foruth one in the list is the universal one the clampps on the column, I forgot about those, would make a good last resort item. Just today ordered , a standard switch, from NAPA, will try to see if any parts are interchangeable......anyway , thanks for the link, I may need it sometime ,,, I think I'll call them also, thanks again
Switch gen14 Transmission - Rearend 1 11-23-2006 05:59 PM
toggle switch / ignition switch help help! 39chevy Electrical 4 08-18-2006 06:04 PM
door switch and brake switch 49dream Electrical 5 02-11-2005 10:58 PM
DIY Shiftlight/ RPM Switch/ RPM Window Switch Junorr Electrical 2 09-07-2004 07:18 PM
Brakes on Toro NAIRB Suspension - Brakes - Steering 3 09-22-2002 07:09 PM
