need 68-74 X body driveshaft measurement - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-21-2009, 12:27 PM
fast68's Avatar
likes chevy trucks & boobies
need to know distance from end of trans tail back to axle pinion yoke for '68-'74 nova apollo acadian ventura with th350 trans
maybe 75-79 is same?
wheel base?
etc?
trying to figure out which of my driveshafts here in my stash is the one from the 74 ventura i had and took it from.
thanks
Old 12-21-2009, 09:10 PM
ericnova72's Avatar
More for Less Racer
Can't help you on the length measurement, but I do know that the 75-79 Nova is the same as the 68-74 as long as the trans is the same length.
Old 12-23-2009, 10:24 AM
tnsmith10's Avatar
when will it rain???
and also if they all have the same rear diff in them. the snout on the 8.5 is 1 inch longer than the 7.5
this is a saver.... GM build codes TooMany2count General Rodding Tech 24 11-23-2009 09:36 AM
Multi-section driveshaft ckucia Transmission - Rearend 23 05-07-2006 12:01 PM
Non-shrinking body filler for Corvette alittle1 Body - Exterior 3 12-20-2003 09:42 PM
74 K5 Blazer body swoo55 Body - Exterior 2 10-26-2003 05:19 PM
74 chevy pu body parts namless_m Body - Exterior 0 12-11-2002 01:03 PM
