Need 9" Ford ring and pinion kit - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-08-2013, 03:13 PM
Where are you guys buying ring gears and bearing kits? I have an open carrier with 350s in it with a little slop. Thinking about rebuild or buy a third member?
Ford 9 inch.
Old 01-08-2013, 03:23 PM
big gear head's Avatar
High Performance Rear Ends
Tom's Differentials, DTS and Randy's Ring & Pinion are the suppliers that I used when I was running my rear end business. They only do rear ends, so they keep the best parts in stock and know what you need.
FORD 9" Ring & Pinion solidaxel Transmission - Rearend 11 06-07-2010 04:08 PM
Need Help Installing Ring & Pinion in 9" Ford S10 Racer Transmission - Rearend 5 04-21-2008 01:27 AM
Ford Racing Visteon Ring & Pinion, 9" Ford ??? acr Transmission - Rearend 2 07-23-2004 09:17 AM
Which Ring & Pinion Kit? Ford 8.8" nightrain_rod Transmission - Rearend 0 12-03-2003 10:48 PM
9" ford ring & pinion install. kid Transmission - Rearend 4 05-07-2003 09:25 PM
