Need Adivce on Front Fenders - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-20-2007, 06:59 PM
Adobe Machine's Avatar
I'm building a '34 3 window coupe, and need some help in locating motorcycle type fenders for the front wheels. In the late 50's we used motorcycle fenders, but the wheels I'm using now are 10" wide in the front..Any sources ? Thanks really ned the help on this one.
Adobe (old as dirt )
Name:	Hot Rod 014.jpg
Old 05-20-2007, 11:20 PM
home brew's Avatar
Last wiki edit: Body and exterior tips Last photo:
Try looking at some trailer fenders. You might have to weld two together to get them wide enough though.
Old 05-21-2007, 12:23 AM
Last journal entry: some progress
the trailer fenders would work unless you have a more curvy design in mind. if that's the case you would want to find a wide rear tire chopper fender. the 280mm and 300mm rear bike tires are getting more popular so you should be able to find fenders wide enough. i would just google for wide tire chopper fenders or pro street chopper fenders you should get a couple hits.
Old 05-21-2007, 12:57 AM
powerrodsmike's Avatar
Wiki Edits: 161
http://www.jpcycles.com/productgroup...&brand=fatkatz
try that.
Cruise around the J&P website some. I'm sure there are more.
later, mikey
BE different....ACT normal.
Old 05-21-2007, 04:26 PM
Thanks for the quick replys !
Wow, really appreciate the quick replys...I'm using those resources now to locate the fenders..
Adobe (old as dirt)
ID:	21340   Click image for larger version
ID:	21341   Click image for larger version
ID:	21342   Click image for larger version
Spindle interchanges bskaggs Suspension - Brakes - Steering 11 06-05-2006 01:29 PM
mustang front clip swap 2wld4u Body - Exterior 5 11-02-2003 09:07 PM
GM Front Diff. Reliability For Full Time Use. M&M CUSTOM Transmission - Rearend 4 10-31-2003 05:36 PM
Hotrodders Knowledge Cluster: Front Clip Installs/Subframes/Frame Swaps Jon Suspension - Brakes - Steering 0 10-12-2003 03:56 PM
body panel alignment gmonkey Body - Exterior 5 09-01-2003 06:50 PM
