Need advice on 200 4r mods - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-01-2006, 06:42 PM
bnewsom's Avatar
Last journal entry: more finished pics
I picked up one from a friend in the salvage business. Fluid smells good but have not pulled the pan. Looking around it seems the popular mods for this trans are to put in a 13 vane pump, an "o" ring .500 valve and an "o" ring low reverse boost valve as well as the spring to firm up 1-2 shift. I'm assuming I won't have to build it but want to add some durability and firm up the shifts a bit. Any advice from the experts is more than welcome. This will be going behind a slightly warmed up Cadillac 425 in a 52 Chevy.
Thanks,
Bob
Old 02-02-2006, 03:59 PM
thewrongshop@yahoo.com
I'm no expert but the man you might want to get the info from is Crolsey .
I have a 200R4 in my 84 van behind a 6.5 diesel after 200,000 miles it was in need of a REBUILD. Adding nothing but some slight upgraded hard parts and a few other odd's and end's it's working fine. But ask the man who knows.
Old 02-02-2006, 04:19 PM
bnewsom's Avatar
Thanks for the info. Does anybody know if I will be screwing up putting these parts in?
Bob
Old 02-02-2006, 04:49 PM
jakeshoe's Avatar
200-4Rs have a few known weak points.
On even a stock rebuild I would use:
Hardened Stator shaft, sun shell. Neither is expensive and both are failure prone.
An upgraded 2nd gear band. Alto Wide Red Eagle.
10 vane pump is my preference. I like it more than a 13 vane. The additional vanes actually take up space and cut volume.
Upgraded TV Boost valves.
Hardened pump rings.
From there:
Any performance upgrades will require at a minimum a Gran National Servo or even better a Fairbanks/ Superior piece.
A valve body kit.
CKPerformance can provide both.
Next,
The forward drum is a known weak point and a billet unit is $400, but if you are making say 400+ HP I would definitely upgrade.
I like to dual feed the direct clutches which necessitates the forward drum.
I also add a 3rd OD clutch.
I like to use Alto reds in the direct drum, stock tans everywhere else, with stock type steels.
Old 02-03-2006, 04:23 PM
bnewsom's Avatar
Thanks for the info. I wasn't planning on going too deep into it unless I had to. Supposedly this trans had been rebuilt not too long before the engine died and the owner junked the car. Fluid looks clean and no burnt odor so I'm assuming all is well until I pull the pan. If the pan looks good, I wanted to do a few things to make sure there is enough fluid pressure and flow to the right places to make this thing live awhile. Maybe I should ask what you would do under these circumstances with improving life and firming up shifts a little as the goal. I'm guesing my 425 make make 275-300 HP and and 350-400 TQ both under 4200 rpm. This is for a cruiser with no plans at all to race.
Thanks again. Bob
information 200 4r turbo 350 700r4 william64 Transmission - Rearend 3 01-29-2006 08:47 PM
A note from the Mods. Everyone please read. Centerline Body - Exterior 0 12-29-2005 10:51 AM
200 4r torque converter help...... isleofwight Transmission - Rearend 3 07-05-2004 02:42 PM
