Need advice on a 383 build - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-24-2012, 07:54 PM
Hello, I'am new to hotrodders forum my name is Nick i live in Ocala, Fl.
I'am working with a old 4 bolt 350 block .30 over. My power goals are 450Hp+ and Torque. ( The only parts i have are the crank kit/all gaskets/MSD Ignition kit). This engine will be going in a 87 camaro with a TH400.
I need help picking the right HEAD, CAM, And STALL CONVERTER.
-Eagle Cast steel crank, 3.75 stroke 6.0 rods/ Flat top pistons +5cc 2 valve reliefs. I hope i ordered the right kit, this kit says +5 cc flat top pistons. When i use this compression chart i came up with 10.5:1. Im using .041 HG/ .020 deck to get these numbers.
-Will a 6 3/4 harmonic do?
-Dart 10521122P - Iron eagle platinum heads, 64cc / 215cc Intake / 75cc exh.
-Lunati 01007 - http://www.summitracing.com/parts/LUN-01007/
-Lunati 30116 - http://www.summitracing.com/parts/LUN-30116/
(That is my guess on the cams, I need some help picking the right cam. This car will be used for Street/Strip.)
- 1.6 ratio roller rockers
-Edelbrock 2601 - Edelbrock Performer Air-Gap Intake Manifolds
-750 or 850 Carb?
I want most my power in the low end to mid, Lets say.. 2000-4000 rpm.
Any other advice you guys can give me the better.
Old 06-24-2012, 08:11 PM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
You're pushing the limit on compression at 10.5 for pump gas, and if you're looking for 450+ rwhp, you're approaching the forged crank and pistons arena. Not that cast won't cut it, just remember it's not bullet proof.
Semper Fi
Old 06-24-2012, 08:16 PM
Ok, Since i have the 5cc flat tops all ready should i look for a head with 70+ cc chamber ? I do agree 10.5 is way to high.
Old 06-24-2012, 08:23 PM
vinniekq2's Avatar
383
this is a comment only,no advice,extrapolate anything you find helpful.IMO the idle is quite choppy with a hydraulic cam over 300 advertised duration.No doubt that cam would be a torque monster in the mid range.Ive used those heads with very good results also.With a nice clean up,they flowed over 250 cfm at .600 in lift..We used a 4.11 gear with the 3 spd auto and later changed to 4.88 and a glide.Both carbs are good.
Old 06-24-2012, 08:34 PM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
I agree with vinnie, that's a lot of cam for a street small block. I have a Herbert 292 in my T's BB 427, with dual 600's and tunnel ram it's over the top and barely streetable, I can imagine your cam in a small block wouldn't have great street manners. If you already have those heads, it might be cheaper to buy some dished pistons if you want to drop the c.r.
Semper Fi
Old 06-25-2012, 02:04 AM
OK did some more research and i found out i can return my cam, These are the new parts..
-Crank/rods/piston kit- http://www.summitracing.com/parts/SCA-1-40755/
3.75 stroke, 6in rods, flat piston 2 valve reliefs 5cc.
-Camshaft- http://www.summitracing.com/parts/LUN-07104LK/
235 int./240 exh. .490 lift
-Intake- Edelbrock Performer Air-Gap Intake Manifolds
-Heads- http://www.summitracing.com/parts/DRT-11621122P/
215cc , 72cc chamber (I chose the 72cc over the 64 for two reasons lower compression and if i decide to add a supercharger in the future.)
I have a couple of questions if anyone feels so kind to help me out.
-I don't know what harmonic balancer to go with.
-Not sure what stall converter to use.
Any other helpful tips would be much appreciated.
Old 06-25-2012, 03:06 AM
By the way, I'am not going to drive this car every day. I plan to drive it to the drag strip its about 15 min drive. I have way to many speeding tickets so for my own good i wont be driving this anywhere but the strip.
Old 06-25-2012, 06:17 AM
vinniekq2's Avatar
damper
I used a "fluid" damper,thats a brand name.Just make sure its sfi approved.
Back around 1980 I was racing at S.I.R.,between rounds after tossing a belt we noticed the outer ring on the G.M. balancer was separating.Thats the closest Ive been to having a balancer failure so since then Ive always used improved balancers.
re convertor?Thats a tough question, the best race convertor will be a little slippery for street use.What will you tolerate?
What first gear ratio will you be using? What diff ratio will be ideal for your goals.
Now a days,there a lot of cars use mild stalls with 4 speed autos with a moderate gear ratio,example: I would rather use a 4 spd auto with 3.7 gears than a 3 spd with 4.1 gears.The launch will be similar as some 4 spd autos have a deeper 1st gear.
Its sometimes easier to work backwards from the results you want to what it will take to get you there.example, I want to have a daily driver that I can run at the track on week ends that will run 13 flat and still not destroy the pocket book everytime I fill up.Look at a new corvette and see what you can do to your car to make it that quick and how much it will cost.You might need a little more power because of weight or modern technology.copy that outline with what works in your car
Old 06-25-2012, 01:14 PM
Sohcnick -- In your Original post you mentioned .020 deck height and a .041 head gasket. This yields a .061 quench. This quench seems a bit high to me. Is it too late to zero deck? Or, you might want to consider a .025-.028 head gasket. Perhaps with flat tops (no dish) this isn't quite as important, but something in the .040-.050 range would still be more desirable. I think you're approaching the outer limit of what works for proper quench.
Best of Luck
PatM
whats better 400 crank or a 383 crank in a 350 sbc when trying to build a 383? onlychevy Hotrodding Basics 14 12-28-2012 07:27 AM
First build advice ceruddick Engine 8 02-16-2012 09:52 AM
383 SBC Build advice Andy Sweeney Engine 5 10-13-2011 05:25 PM
need advice on 383 build up mxbadboy03 Engine 4 10-12-2007 08:33 PM
First build. Need advice. wayneair Engine 6 10-05-2005 08:34 AM
