need advice on 383 build up - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-10-2007, 04:46 PM
ok i'm gonna use a 350 4 bolt man block to build a 383 i'm gonna buy a eagle street and strip rotating assembly 9:9:1 compression with 64 cc heads i looking to buy sum alumnium 64cc heads but i dont know wat size runners do i need?170cc or 200cc or wat?? also am looking to run a compcams 501 lift cam kit with a edelbrock intake manifold and shorty headers and this is gonna be in a 1985 s-10 long bed so wat size runners do i need wat brand heads and wat size carb do i need to run and i want a double pumper carb and about wat horse power can i expect to the ground??
Old 10-11-2007, 07:36 AM
AHotRod's Avatar
Rather than guessing at what will work together, I suggest that you follow a proven combination from GM Performance in their ZZ3 - 383 CID.
ZZ 383 Tech Specs Block Part Number:
88962516
Block Type:
Cast iron with 4-bolt main caps
Bore x stroke (in):
4.00 x 3.80
Camshaft duration (@.050 in):
222 degree intake / 230 degree exhaust
Camshaft lift (in):
.509 intake / .528 exhaust
Camshaft Part Number:
12370846
Camshaft type:
Hydraulic roller
Compression ratio:
9.6:1
Connecting Rod Part Number:
12497624
Connecting rods Type:
Heavy-duty PM steel
Crankshaft Part Number:
12489436
Crankshaft Type:
Forged steel
Cylinder head Part Number:
12464298
Cylinder head Type:
Fast Burn aluminum; 62cc chambers
Displacement (cu in):
383
Engine Name:
ZZ383/425:
Engine type:
Chevy small-block V-8
Ignition timing:
32 degree total @ 3000 rpm with vacuum advance disconnected
Maximum rpm:
6000
NOTE:
Distributor with melonized steel gear MUST be used with long blocks and partial engines with steel camshafts, or engine damage will occur. We recommend HEI distributor P/N 93440806.
Piston Part Number:
12499103
Pistons Type:
Hypereutectic aluminum
Recommended fuel:
92 octane
Rocker arm ratio:
1.5:1
Rocker arms Part Number:
12367345
Rocker arms Type:
Aluminum roller style
Valve size (in):
2.00 intake / 1.55 exhaust
Big-block-style power from a small-block engine!
If you're looking for a small-block Chevy that makes big-block power, we've got the engine for you! For the ultimate GM Performance Parts small-block crate engine, choose the ZZ383 a combination of Fast Burn aluminum performance heads and a 383" stroker small-block that can add up to 425 horsepower and 449 lb.-ft. of torque.
A carefully engineered balance of torque-producing bottom-end power and horsepower-inducing Fast Burn cylinder heads combine for the ZZ383/425's stellar performance statistics. The Fast Burn heads have large 2.00"/1.55" valves and specially designed chambers that draw in lots of air and fuel, burning the mixture quickly and completely. It's a combination that generates great mid- and high-rpm power, which, when combined with the 383 cubic inch displacement, creates an awesome all-around performer.
The ZZ383 has a specially modified engine block and 3.80"-stroke crankshaft, which produce 383 cubic inches of pure performance. The reciprocating assembly is comprised of heavy-duty components including a 4340, nitrided, and induction-hardened forged crankshaft, and unique, heavy-duty powdered metal rods. It's 425 horses of bulletproof performance.
With the ZZ383/425, you get the power of a big-block with the size and weight of an aluminum-headed small-block.
If you've never driven a car with a stroked small-block and the top end components to support it, now is your chance!
**Applications have not been validated. They are merely suggestions of how you might enjoy your GM Performance Parts crate engine. Some applications may affect engine warranty. Some applications may not be emission legal; check state and local ordinances.
Read about it here: http://www.gmperformanceparts.com/En...8772&engCat=sb
Glenn
Old 10-11-2007, 05:28 PM
1BAD80's Avatar
The Smell of Nitro in the morn
Last wiki edit: How to adjust valves Last photo:
Wiki Edits: 2
Here is a site from the Knowledge Base,
http://www.ryanscarpage.50megs.com/combos1.html
has over 100 motor combs
Luv the smell of NITRO in the morning.
Old 10-12-2007, 05:31 PM
yea but i want to run my own set up and not sum 1 elses build
Old 10-12-2007, 08:33 PM
383 help
mxbadboy 3 I currently have a 383 in a 67 camaro appoximate weight of 3500lbs that runs 12.45 on a g-tech meter. The motor is basically the edelbrock rpm performer top end package 64 chambers 170 runners aluminum heads. Speed demon 750 DP with 10.1 keith black pistons. On the chasis dyno it put 323 hp behind a th 400. in a s10 this combo minus th400 would haul from what I heard every 100lbs of weight reduction in vehicle is a tenth of a second. hope this helps
how to build 383 chev engine 72trucks Engine 4 05-20-2007 10:24 AM
newbee question about 383 build jgaona Hotrodding Basics 5 08-17-2006 03:03 PM
How do I build a 383 stroker? KFXrider88 Engine 2 06-16-2006 12:10 PM
How do I build a 383 stroker? KFXrider88 Engine 1 06-11-2006 07:47 PM
496 build up >>> NEED ADVICE terror385 Engine 5 11-17-2003 08:42 AM
